Quote:
Originally Posted by cobraguy
First off welcome to FTE. Now what are we working on. You can use the bellhousing from any 289-351 the only exceptions are the early 5 hole 260/289 and the 351M. Flex plate and torque converter should be available at a parts house or tranny shop near you. You will also need a starter.
Exactly. Early 65 V-8's used a 5 bolt bellhousing. Later 65 V-8's went to the 6 bolt bellhousing.
5 Bolt bellhousings are rare, but not impossible to find (just expensive).
