Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 04-14-2008, 11:00 PM
mustange70's Avatar
mustange70 has a good reputation on FTE.mustange70 has a good reputation on FTE.
My mud racing 400 build, is done . ..
well kinda, still need a water pump, crank pulley and tall valve covers to clear the rockers but here you go:
starting at the block, the block has been decked and and a .030 overbore, everything was aligned honed and SPS bolts on the bottom end, the rotating assembly has been fully balanced, the pistons are a set of cleveland flattops, zerodeck, the rods were bushed and the pistons use a floating pin and not pressed, and reliefs wer cut into the pistons to clear the valves, going up into the heads we have a set of closed chamber 4v heads, they have a fulll port and polish on both the intake and exhaust, SS valve, dual valve sprign setup good for 140lbs of seat pressure, roller rockers, screw in studs and guide plates with custom length hardened pushrods, cam is onlly a comp cams 275 deh, and we guestimate (and some dyno sims.) about 450hp and about 500ftlbs around 6-6500rpm, should rev to nearly 7, but a rev limiter will keep it to no higher than 6500, intake is a rosch B351 ported for cleveland heads, price intake spacers and a holley 750dp with a few mods to free up some flow.
__________________
Cody, Edmonton
AB/BC Chapter Leader
82' Flareside: 2/4 Drop, 350hp 351W, Custom interior
81' 250 mudder: home fabbed lift & dana 60 SAS , 400C 4v, 4sp/205
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-15-2008, 08:28 AM
hollenjoe is starting off with a positive reputation.
Wwow nice, it should be a monster!, did you go 4 bolt mains? It should help keep the 7k, someday il make my 400 look like that! The funny thing is that this built goes against low revrr 400 believers...
nice job man
__________________
"All right baby, see what I´ve got right here in my hands, I´ve got it right in my hands to score you baby, I think im gonna yank on a one town! Look Out!" Uncle Ted
  #3 (permalink)
Old 04-15-2008, 08:44 AM
job1bf is starting off with a positive reputation.
love it..
that is close to the same build i want to do...i will be very interested in how it performs. Any dyno time on the schedule?
  #4 (permalink)
Old 04-15-2008, 08:53 AM
Hey mustang another thing, those flat tops with 3cc or 4cc of velvereliefs and 0 decked with closed chambers I estimated a scr of 12:1 , thats too much unless race fuel will be used, Are they dished?
for your built I estimated :
HP 495@6000
TQ 503@4500
__________________
  #5 (permalink)
Old 04-15-2008, 10:04 AM
mustang81 is starting off with a positive reputation.
Nice built !!!
  #6 (permalink)
Old 04-15-2008, 10:01 PM
xlman is starting off with a positive reputation.
Beautiful build! Congrats so far! Can't wait to do my 400 that well. How much was taken from the block when it was decked? A simple truing or a specific amount? Just curious for this engine.
__________________
1982 F150 Stepside - 400, 4spd/od,
1967 Mustang - 200, 3spd
  #7 (permalink)
Old 04-15-2008, 10:04 PM
mustange70's Avatar
race fuel only in that beast and i'm not sure on the valve reliefs as there were custom cut by the machinest to fit the heads, and we didn't bother to cc' anything either do to lack of time, but i calculated the cr out to 11.5ish without the valve reliefs, so probably 11:1 sounds close, but it could be higher, i will do a compression check before we fire it up so we can get a baseline for future reference., as far as the mains, well the block was aready preped by the time i found out about the 4bolt mains, yeah i could've added them in but i didn't think i'd have the extra cash avaible at the end for the extra cost.
There's probably going to be no dyno time just due to dyno avaiblility, and i have very little time myself to do it as well, but i'm hoping i can sneak it on a chassis dyno sometime this summer at one of the car shows that comes through lethbridge alberta. The block was taken down as much as one can safely take it down, i wanna say .030, but i can't say for sure cause i don't have the sheet in front of me.
Yep, and its sure gonna piss them chevy guys off too
__________________
Cody, Edmonton
  #8 (permalink)
Old 04-16-2008, 12:18 PM
JAJAJ amazing built, so why dont you try a 1/4 mile? on what vehicule are you dropping it to? sorry for being so curious, you´re doing something i want to do some day with my 400 ....
__________________
  #9 (permalink)
Old 04-16-2008, 04:07 PM
beartracks's Avatar
beartracks is starting off with a positive reputation.
That manifold gives me a woody! I'd expect close to 500hp if that thing holds together, although I'm not familiar with the cam specs.
__________________
Bear Tracks
1977 F-100 Ranger XLT,400,C6,GV
Mod's Listed in Gallery
Click Here To Help Support FTE
  #10 (permalink)
Old 04-16-2008, 08:01 PM
mustange70's Avatar
the motor is going into my mud bogger, no 1/4 mile strips around my parts. but yeah the cam is rather mild so i'm only expecting mid to low 400's, but still i could be completely wrong.
__________________
Cody, Edmonton
  #11 (permalink)
Old 04-20-2008, 10:31 AM
stans is starting off with a positive reputation.
If that engine had an Edelbrock Performer 351M/400 manifold and a balancer painted black it would look exactly like the 400 that I built for my 1972 Gran Torino Sport many years ago. That's a nice looking engine!
  #12 (permalink)
Old 04-22-2008, 06:20 PM
anyone knows if a stock c6 can handle a strong just rebuilt 400 with an estimated of 460lbs of torque? It was behind the engine when it was a 351m and worked perfectly buts all original on the inside....
thanx
__________________
  #13 (permalink)
Old 04-22-2008, 07:38 PM
JBradley500 is starting off with a positive reputation.
id have to say it would without a doubt...they can take alot of abuse with no issues.
__________________
  #14 (permalink)
Old 04-22-2008, 07:44 PM
UTfball68's Avatar
UTfball68 is gaining momentum as a positive member of FTE.
Quote:
thanx
I'd have to agree with JBradley...however I wouldn't exceed 500hp or 600 ft/lbs of torque...just in case you're planning on anymore future mods.
__________________
___'77 250 400 37 Boggers____'96 350 CC 460 35 SSR's_____'79 Bronco 351M 35 M/T's
Ben
  #15 (permalink)
Old 04-22-2008, 08:42 PM
My 1969 460 came from the factory with a C6, and that engine produced 500ftlbs of torque. Still had no tranny issues at all after it was pulled with 120K on it.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
