Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #16 (permalink)
Old 04-22-2008, 08:54 PM
mustange70's Avatar
mustange70 has a good reputation on FTE.mustange70 has a good reputation on FTE.
yeah your tranny should be fine, but still it never hurts to put a good cooler and new fluid and what not in it.
Hopefully this upcoming weekend i can get the motor dropped in the truck, my parts from summit are in, new high volume water pump, underdrive crank pulley, new plug wires, and some nice shiny tall valve covers (wanted soem steel ones but no one makes a tall steel valve cover, and spacers were more expensive than the new valve covers), other than plugs and a new fuel pump that i'll get from napa i have everything i need to put it together and drop er' in, i'll still need to port my homemade headers to the bigger 4v ports though, for the rad i'll just keep it in the stock location, as i've already made the mounts to move it to the bed, but i want to make sure it will run ok with it in the stock location before i change anything, will need to rewrie everything and get some murphy switchage guages to protect the motor (they have addjustable points on the oil pres. and water temp. that will shut the motor off if reached) and its racing time
__________________
Cody, Edmonton
AB/BC Chapter Leader
82' Flareside: 2/4 Drop, 350hp 351W, Custom interior
81' 250 mudder: home fabbed lift & dana 60 SAS , 400C 4v, 4sp/205
  #17 (permalink)
Old 04-28-2008, 10:33 PM
mustange70's Avatar
Ran into a snag over the weekend, the water pump i got from summit ended up having a bent impeller, so i gotta send it back and get the pump replaced, but i have a stock one i'll run in its place for the time being, got the covers and the pulley and the wires i needed so i'm good to go on that front. I did some surgey on the intake as i was afraid of having water sitting underneath it and the the valley pan from pricemotorsports, so i chopped the bottom of the intake out, other than that i wasn't able to get the motor dropped in, but the old motor is ready to get yanked, just have to seperate from the tranny and pulled on it out.
I ordered a few more parts as wll, i ordered a new lakewood bellhousing thats sfi approved for exploding clutches , also have an external oil line kit from price motorsports coming as well, then i will still need to port the headers for the bigger ports, do some cleaning and painting and i'll be good to go to drop the new motor in and fire it up, i'm hoping that since i have a short little holiday this weekend i will be able to get everything up and running. A few pictures:
the old:
the new:
the mods to the intake:
__________________
Cody, Edmonton
  #18 (permalink)
Old 04-29-2008, 08:09 AM
mustang81 is starting off with a positive reputation.
what kind of pulley on your crank ? mine is bigger and have a small weight (one inch long) and the pulley have 4 holes, now i don't what position it's going back. Can be in 4 differents position ?
  #19 (permalink)
Old 04-29-2008, 08:10 AM
hollenjoe is starting off with a positive reputation.
nice, post a youtube video of it firing up!
__________________
"All right baby, see what I´ve got right here in my hands, I´ve got it right in my hands to score you baby, I think im gonna yank on a one town! Look Out!" Uncle Ted
  #20 (permalink)
Old 04-29-2008, 08:15 PM
mustange70's Avatar
the pulley is a 4" morso underdrive crank pulley, the 4 bolts are still there, just behind the the pulley. the pulley actually usesthe crank bolt (it has a spacer behind it and a longer grade 8 crank bolt) and the 4 bolts it normally bolts to are replaced with allen head bolts and they are there to keep the pulley from spinning on the crank bolt.
there will be video .
__________________
Cody, Edmonton
  #21 (permalink)
Old 05-07-2008, 11:41 PM
mustange70's Avatar
It lives , got the motor dropped in and running, and dang she's a gooder have a a couple videos after initil break in, keep in mind that the truck is never more than half throttle in any of the clips, didn't even get into the secondaries (i got it up to 5000rpm in the one)
at idle just after break in:
YouTube - my 400 at idle
first test drive:
YouTube - a "mild" 400 ford
__________________
Cody, Edmonton
  #22 (permalink)
Old 05-08-2008, 08:34 AM
wow nice sound, how did it feel?so in the videos what fuel are you using? besides that hey change to an open filter!!!! other than that cool engine and headers!
__________________
  #23 (permalink)
Old 05-08-2008, 08:29 PM
mustange70's Avatar
VP c12, and i will never use an open element filter on the truck, they suck in to much water in the mud, thanks though .
__________________
Cody, Edmonton
  #24 (permalink)
Old 05-09-2008, 03:00 AM
jajajj yeah you`re right, it just looks funny, nice man congrats!
__________________
  #25 (permalink)
Old 05-18-2008, 11:57 AM
Bruteforce1974 is starting off with a positive reputation.
hell yea i have to say that is a sick ass 400 that idle is breath taking!
  #26 (permalink)
Old 05-19-2008, 11:55 PM
mustange70's Avatar
Well i've already broke it, don't know what caused it but i bent both ppushrods on #4 cyclinder, i htink i had some valve float, i just hope the valves didn't hit the pistons.
__________________
Cody, Edmonton
  #27 (permalink)
Old 05-20-2008, 09:43 AM
80broncoman is starting off with a positive reputation.
I hope the pusrods are all thats bent too.
By the way up in post #17 what kind of headers are those on the old engine?
__________________
Real men don't wear Bowties
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
