Diablo Predator
The Diablosport Predator for the Diesel 6.0 does adjust for shift firmness, but I can't find anywhere if it adjusts for different tire sizes, but this is generally a standard option on tuners for the last ten years. It says it comes with all the standard Diablosport Predator features which would include adjusting for tire size on the speedometer.
I suggest you do an internet update on the programmer to make sure you have the latest updates - you will need a cable to connect it to the computer but can get all the information you need from their website. You'll know what you can change as soon as you plug it into your truck.
DiabloSport :: Gas and Diesel Tuning Systems
You get 3 modes for the 6.0
Tow/Haul, 60HP, 100HP
If you are going to run the 100HP, better get an EGT guage
it also monitors codes, you can use it to trend engine/trans variables and log them to a laptop.
It also lets you remove the speed limiter. - best option yet.
I have to say I definitely like mine.
The Diablosport is a good tuner. Only adjust parameters you know about. Don't go wild with the shift firmness, too much is hard on the pump in the tranny and can lead to premature failure. You can adjust the tranny for tire size but on all diesels and most gasser SD you can't correct the speedo for larger tires.
dirtroaddevil
10-27-2003 07:10 PM
Motoxman_117
21
06-07-2003 07:25 AM
