Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-14-2008, 10:37 PM
x79f100x's Avatar
x79f100x is starting off with a positive reputation.
Question Another transmission swap question...
Quite simple, i think.
I have a 1979 f-100
302 with a c4 transmission, column shift (P, N, D, 2, 1)
I am looking to replace it with a stronger c6 transmission.
What issues will i run in to (driveshaft length and shifting is a main concern)
Thanks, Cody
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-15-2008, 12:33 AM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
Waste of time and money. C4 just fine behind a 302. C6 just eats a bit more power. You can beef up the C4 if you need to.
  #3 (permalink)
Old 04-15-2008, 04:01 AM
HemiEater's Avatar
HemiEater is starting off with a positive reputation.
Quote:
I feel the same way...
Just in case you're curious, power loss for various auto transmissions:
Please remember these are approximate values, and were provided by Car Craft Magazine.
Powerglide_____18 hp
TH-350________36 hp
TH-400________44 hp
Ford_C-6______55-60 hp
Ford_C-4______28 hp
Ford_FMX______25 hp
Chrysler_A904__25 hp
Chrysler_727___45 hp
  #4 (permalink)
Old 04-15-2008, 08:39 AM
x79f100x's Avatar
wow...
I knew it ate more power but
I have a $1,200 custom built C4 in it right now, redline cluthes and all. I was just curious to see the difference i would get with 4 gears instead of 3.
I'll stick with what i have. Thanks yall.
  #5 (permalink)
Old 04-15-2008, 09:14 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Quote:
C6 is also a 3-speed.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's, FRPP Mass Air, TweecerRT 282HP
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #6 (permalink)
Old 04-15-2008, 09:24 AM
x79f100x's Avatar
1. Open mouth
2. Insert foot
  #7 (permalink)
Old 04-15-2008, 05:52 PM
For $2000+ you can have the 4 speeds...
TCI Auto: AOD StreetFighterŽ Transmission
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
