Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-14-2008, 09:15 PM
IHdieselfan is starting off with a positive reputation.
used oil for fuel
Over the years from mine and dads grading co. we have saved up 1200 gallons of used engine,trans,gear,and hyd oil. I have enough parts to make pumping and filtering system, using 3 filters first a 25 micron then 10 micron and then a 3 micron then across a magnet.
mixing this oil 50/50 with diesel i'm thinking of running it in my idi
I think it should be clean enough to keep from screwin' up injectors or ip
any thoughts.
__________________
'88 F-250, 7.3L, reg cab, 5spd, 2wd, c9 axle, custom
'95 F-250, psd, ext cab, E4OD, 4x4, 39 axle, lariat
'02 Explorer, 4.0L, 5R55W, 4X4, 3.55, XLT
countless other company diesels(deere's, cat's, detroit's cornbinder's)
  #2 (permalink)
Old 04-14-2008, 10:36 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
Yes,
http://www.ford-trucks.com/forums/72...-15w40-ok.html
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #3 (permalink)
Old 04-15-2008, 12:15 AM
CheaperJeeper's Avatar
CheaperJeeper is starting off with a positive reputation.
I'd do it. At $4 a gallon for diesel, even if you only burned 100 gallons before it toasted your pump, you'd still break even! Naturally you're going to be able to burn a LOT more of it than that before you hurt anything - probably never hurt it at all if you filter it down to 3 microns. 1200 gallons at $4 per gallon savings is nearly 5 grand! If I had that kind of supply, I'd filter the heck out of it and burn it in a heartbeat.
__________________
1986 F250 Super Cab 4x6 (dually), 6.9 Banks TURBO, SMF & ZF5-47, 4.10 gears, 3" Banks straight-pipe exhaust. Mileage unknown
SOLD! 1986 F250 Super Cab 2WD, 6.9 NA, C6 Auto, 3.55 gears, K&N, dual RAM-air, custom Y-pipe to 3" ATS exhaust. 120k? 220k? Dunno’ but still running strong when she left...
  #4 (permalink)
Old 04-15-2008, 12:30 AM
tbone91 is starting off with a positive reputation.
Just curious -- is there any chance that there is some off-road diesel in the mix? It'd be a shame if you got "dipped" and it came up red...
__________________
91 F350 dually crew cab, Rebuilt E40D + TC, ATS turbo, stock intake & exhaust
  #5 (permalink)
Old 04-15-2008, 01:42 AM
George D.'s Avatar
George D. is starting off with a positive reputation.
Are any of the oils synthetic? I know we had to stop running the heaters at work off waste oil because the synthetic wont burn very well. If not you'll be fine.
__________________
94 F350 Crew Cab Long bed 4X4 7.3L IDI Factory Turbo, AKA The Land Yacht. E4OD, 4.10 posi. Getting further from stock with 35 inch BFG alterains on 16 inch micky's, straight pipe, Triple A-piller pod with pyro, boost, modifyed stock oil presure gauge, tc lock light&switch
  #6 (permalink)
Old 04-15-2008, 11:25 PM
boots6868 is starting off with a positive reputation.
am I just missing something when you drop your oil out of your engine is it not already filtered. Or is that not adequate enough to burn in your tank. Im new at these diesel technology bear with me please.
could a person make up his own filtering device? thanx
  #7 (permalink)
Old 04-15-2008, 11:33 PM
George D.'s Avatar
The oil in the pan is not filtered the oil circulates from the pan to the filter the gose threw the rest of the engine cleaning any gunk or deposits and flushing them to the oil pan.
__________________
  #8 (permalink)
Old 04-15-2008, 11:40 PM
Quote:
What he said...
PLUS the oil filter only takes out particles bigger than either 10 or 20 microns but your fuel filter takes out anything over 5 microns as I recall (can't remember the exact specs on the two, but someone will probably chime in with that info).
You need to filter it a lot better to use as fuel than what you need to do for lubrication.
__________________
  #9 (permalink)
Old 04-15-2008, 11:52 PM
George D.'s Avatar
How much ATF do you guys think it would take to make highway diesel look like off road fule? I have about a litle over 3/4 a tank in my big tank/anything my truck will run off tank and about 2 galons of ATF. Normaly i wouldn't worry about it but I may be going out of town this weekend and don't know what to expect as too tank checks.
__________________
  #10 (permalink)
Old 04-16-2008, 09:39 PM
No synthetic oil.
Yeah some off-road from where I change fuel filters and dump the fuel out of of the old filter. but not much
filter micron ratings:
6.9l- 6 microns
7.3l- 12 microns
The thing is making the filter system is the trick since i have all these extra parts laying around
__________________
  #11 (permalink)
Old 04-17-2008, 12:59 AM
Quote:
6.9l- 6 microns
7.3l- 12 microns
Which filter - oil or fuel? I'm thinking fuel, because the specs I've seen show the PSD filter removing particles half the size of the one for the IDI...
__________________
  #12 (permalink)
Old 04-17-2008, 08:29 PM
right thats for fuel filters sorry.
6.9l fuel filter 6 microns
7.3l idi fuel filter 12 microns
oil filters are IDI 25 microns psd 19 microns
__________________
  #13 (permalink)
Old 04-17-2008, 09:47 PM
the grimlin is starting off with a positive reputation.
I filter my used oil with used Fleetgard fs1000 filters rated at 10 microns that I bring home from work after services. I then mix 50% off road fuel/stove oil/what ever is cheep at the time 40% used motor oil 10% used transmission fluid to keep things clean and also to say I am running used transmission fluid if I get stopped. That way I don't feel so bad,It's kinda like a little white lie
I did this for a few years on my last truck with no problems other then a plugged filter once. O also a few times I got the fuel kinda thick so the motor would chug-chug-chug then I would just switch tanks quick then stopped by and add some more diesel.
Also a pointer to anyone thats going to do this run the used waste oil/mix in your rear tank so if you do boo boo the motor picks up good fuel from the front tank faster. I also convert the truck over to a more common filter head from Cummins that takes and 1" 14 thread filter like the ff105/fs212 or even the fs1000 they are all 10 micron and the ff105 if you have to get it new is cheeper then the stock 7.3l filter.
starr
  #14 (permalink)
Old 04-17-2008, 11:11 PM
If you told them you were running used transmission fluid here, they would hand you a ticket for 5000 dollars plus court costs.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #15 (permalink)
Old 04-18-2008, 10:44 AM
Quote:
Why? As long as you own at least one vehicle with a slush-box soy you can at least say that it is used oil from your own tranny. If it is ATF that you bought and paid retail for, you've already paid all the taxes on it, right?
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
