Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-14-2008, 08:41 PM
boggerted is starting off with a positive reputation.
My carb needs some help
On my 84 F250 351w 2bl carb, if you are driving at low rpms, then punch the throttle, it bogs down and starts popping through the carb. If you let up on the gas, it stops and accelerates fine. Ive rebuilt the carb and it runs fine otherwise.
__________________
2000 Ford Excursion-6.8L V10 gas guzzler
1984 Ford F250- my project- 351w
4 speed w/ granny
gauge set
glasspacks
Holley 4bbl
Edelbrock performer intake
  #2 (permalink)
Old 04-14-2008, 09:12 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE.
Take the aircleaner off, and with the engine off, look down the carb throat, and just barely push the throttle back. Did you get anything out of the squirters for the accel pump? You can try again, and while watching the squirters, and making a mental note of how you are pushing on the throttle, push it back all the way. The streams of gas should start right away, and be very strong, especially since you just rebuilt it.
You can't have any delay in the fuel squirting down the carb throat, or you will get a bog and the popping. The popping is the engine leaning out. Don't experiment too much with out starting the engine, or you will flood it.
If that all looks good, then the timing could be way off, and it can have this symptom, but if it did not do it before, and after the carb was rebuilt it does it, then I would suspect you may have lost the check ball out of the pump circuit, and forgot to put it back in.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 05-28-2008, 09:49 PM
Do you have a diagram of the springs inside the accelerator pump? Mine uses the diaphragm with the spring permanently attached if that helps at all, because Im not seeing any fuel squirting in, and the diaphragm is new.
__________________
4 speed w/ granny
gauge set
glasspacks
Holley 4bbl
  #4 (permalink)
Old 05-28-2008, 10:13 PM
Franklin2's Avatar
Here's a exploded view.
Carburetor Factory - American Motors 2100 Exploded View
More than likely you are missing #41, or #33 or #34.
__________________
Dave F
  #5 (permalink)
Old 05-28-2008, 10:45 PM
I know 33 and 34 are there because I had to redo it after forgetting the check ball the first time. The rubber part (41) was replaced, but it doesnt seem to fit tight on the metal, it flaps around loosely. Is that normal?
__________________
4 speed w/ granny
gauge set
glasspacks
Holley 4bbl
  #6 (permalink)
Old 05-28-2008, 11:11 PM
85lebaront2 is starting off with a positive reputation.
No, you have to pull it through until the "bump" comes through the hole.
__________________
Bill Vose (Old School Hot Rodder)
1985 LeBaron convertible 2.2L TurboII
1986 F350 crew cab DRW 460ci
1986 LeBaron convertible 2.2L TBI (dead)
1986 Turismo 2.2 (race car)
1989 LeBaron J body convertible
1989 LeBaron J body coupe
1993 Grand Caravan 3.3L
1995 Lincoln Continental (project car)
http://www.oldschoolhotrodder.com
  #7 (permalink)
Old 06-01-2008, 01:31 PM
Piffery1 is gaining momentum as a positive member of FTE.
The elastomer valve shank should pass through the hole in the center of the pump chamber. You may have to apply a little grease to get it to pass through the hole and seat properly.
  #8 (permalink)
Old 06-01-2008, 03:09 PM
It did pull through past the bump, it just doesnt seal right. I think though that the metering rods not opening is also causing me problems.
__________________
4 speed w/ granny
gauge set
glasspacks
Holley 4bbl
  #9 (permalink)
Old 06-01-2008, 03:27 PM
Sounds like you may have the wrong size elastomer valve. Do you still have the old one to compare? I think there may be two different (at least) sizes. The metering rods are actuated by a removable cam on the throttle shaft; is it still properly in place?
  #10 (permalink)
Old 06-01-2008, 06:43 PM
thats the problem, that cam isnt a tight fit on the shaft due to wear, so it takes a while to engage, and sometimes, it wont engage at all, it just spins around.
__________________
4 speed w/ granny
gauge set
glasspacks
Holley 4bbl
  #11 (permalink)
Old 06-01-2008, 09:55 PM
I think your best bet is to get a rebuilt. Or, find a cheap used one and get the parts you need off it. I sent you a PM with a link to one on ebay that looks pretty close to what you've got.
  #12 (permalink)
Old 06-02-2008, 06:26 AM
Thanks piffery for the link. I think im going to get a new holley 4412 as a replacement
__________________
4 speed w/ granny
gauge set
glasspacks
Holley 4bbl
  #13 (permalink)
Old 06-02-2008, 04:50 PM
Ooooh, I'd hate to spend that much money for a new carb! Can you crimp or wedge the cam to fit tightly on the throttle shaft?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
