55 ford after market gas tanks
iam installing a 1970 ford mustang gas tank under the bed . my question is will the mustang sending unit work with my new VDO gauges ? or will the sending unit that came with the gauges fit in the tank ? iam sure some one has done thi befor little help please thanks a bunch !
Somewhere on FTE the OHM readings for Ford sending units has been listed. Try doing a search on "OHM reading" or "sending units". If VDO doesn't list the OHM reading that their gauges operate within then call them and ask. I doubt if the VDO unit will fit in the Mustang tank so you will need the Mustang sending unit or maybe even modify the Mustang unit to accept the VDO sender. I guess another possible would be to have a radiator shop close up the Mustang sender location and cut a new hole in the top for the VDO unit. I used Autometer gauges with mine and Autometer modified their guage to work with the Ford sending unit. It worked but not 100% accurate.
Daytona F1
05-05-2010 10:23 AM
choped&droped
05-01-2008 08:30 PM
LEckart
02-20-2004 07:40 AM
