Here are the part numbers for the F650 lower panel
Okay guys, i know some of you (especially Ed ) have been going nuts trying to figure out the part numbers for that F-650 lower dash I used for the upfitter switches : https://www.ford-trucks.com/forums/7...duty-pics.html
PLEASE read this carefully to understand how all this works.
I did this taking a chance and looking at exploded views at the Ford dealership on how it would bolt up. NOW.. since the late 99 to 07 dashes are very similar, the panel SHOULD bolt up the same.
There are 2 panels you could choose from - one is a one hole and one is a two hole - those holes being for parking brakes. IF you want a flat area, order the one hole version!! The holes are about 3/4" in diameter and I was going to mount 2" gauges there anyway so it didn't matter.
Also I believe the colors are all the gray/flint on these - again it didn't matter to me since I was going to paint it or have it wood grained like I did.
These show to fit a 2000-2003 F-650 truck :
1C4Z-80044D70-AAB (1 hole version)
1C4Z-80044D70-CAC (2 hole version - what I used).
NOTE : the parts manager did a nationwide inventory check and NATIONALLY it shows 9 total available for the AAB and 8 total available for the CAC.
If you have a 2005-2007 Superduty, and try to find an F650 dash panel for THOSE year models, it will show NOT AVAILABLE. However, I do believe the lower panels on 2000-2007 bolt up the same so these panels SHOULD work for you !
I hope this helps !
I hope this helps !
norman2012
05-13-2023 09:57 AM
Ford's Secret Zoodad: Putting a hole in the header panel for the snorkel to breathe - without water!
Y2KW57
22
08-26-2020 10:35 AM
