Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-14-2008, 03:18 PM
newbyyhead03 is starting off with a positive reputation.
carb for blow thru
i have a edelbrock 600 w/ electric choke will this work for a blow thru turboed 292 y block if not what wud b an acceptable carb ? i am on a tight budget . looking at about 5-9 #s of boost engine is stock . also only a single turbo setup thinking of a smaller one off a 4 banger to keep spool up in lower rpms cruising and daily driver range- any suggestions?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-14-2008, 08:19 PM
royalchoppers is starting off with a positive reputation.
I have been looking at doing the same thing for my 352 but using a Holley 650. Here is a good link on how to modify a carb for blow through.
Blowthrough Carb How-To
Using a too small of a turbo like one that is good for a civic would cause your 292 to flatten out in power low in the rpm range. You would want to use one larger turbo or two small turbos.
__________________
In 4130 we trust.
www.myspace.com/royalchoppers
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
