3.0 has unique bolt pattern. Mazda M5OD has bellhousing integrated with tranny case. So you need Ranger M5OD tranny for 3.0 ONLY!
I got tranny from russian truck and used bellhousing from A4LD adding external slave cyl.
You may use any tranny for 3.0 from 1986 to 2006 Rangers. There are 2.9 and 4.0 Aeros and rangers. So be carefull.
It is not all.... You need flywheel, clutch, clutch pedal from truck with 5 st tranny.
First of all collect all parts you need to swap.
BTW. Autos are usually longer manuals. May be DS swap may be required.
Quote:
From what research I did, I think older aeros used a lighter duty mazda tranny and I think the 4 cylinder aero's from the mid 80's used a smaller mitsubishi tranny (?).
All 3.0 aeros with manuals had M5OD R1 trannies still used in Rangers, B series and E-series mazdas. 4-cyl aeros had trannies like Ford Scorpio 2.0. There are ford ovals everywhere inside tranny, so I'm not sure. May be this tranny was designed in Essex, May be in Kohln but may be in Japan..... But parts awailable on our market are made by Ford in Germany now.
This is photo of 4-cyl Lima engine in aero. Clone of early 4-cyl cologne engine.
There is a way to "enforce" this tranny - to swap all parts inside with 4.0 tranny (Ranger, Aero, Explorer and other).
This tranny is easy to add T-case. Manual T-cases are awailable too, but rare, generally made for Japaneese market for Mazda E2200 AWD.
