Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 04-14-2008, 12:55 PM
phillips91 phillips91 is offline
Garage is empty, add now
phillips91 has a great reputation on FTE.phillips91 has a great reputation on FTE.phillips91 has a great reputation on FTE.phillips91 has a great reputation on FTE.
new to diesel as well as biodiesel
i have a few questions about biodiesel. i have always heard that it has to be made from veggie oil, but i watched a documentary about it where the guy was showing how it was made and he pumped his waste oil directly out of a grease trap. his grease was a combination of fry oil and hamburger grease. can biodiesel be made from animal fats as well as vegetable oil? i wanted to try to make some, but could not locate pure vegetable oil without buying it new(at $15 dollars a gallon around here). everything i found used was a mix of burger grease and fry oil.
to hear biodiesel advocates tell the story, bio is the best thing ever. run 100% biodiesel and get better lubricity, longer lasting engine, no performance decrease, etc. and to hear the oil companies and auto industry tell it, if you even mention the word biodiesel within 20 feet of your truck you will have catastrophic engine failure. i suppose the truth is somewhere in the middle ground. i was excited about trying to make my own fuel until i read on fords page that they do not recommend running anything more than B2 in the powerstroke. is there any reason they say its not safe to use more than B2 other than bowing down to the oil gods? i mean companies.... i would like to be able to run at least B20-B50, but dont want to fry my engine by doing so.
  #2 (permalink)
Old 04-19-2008, 10:32 PM
bradyracing bradyracing is offline
bradyracing is starting off with a positive reputation.
Some people think that biodiesel can only be made from veg oil. Some think it can only be made from soy oil. In reallity it is the transesterfication of triglycerides which include veg oil and animal fats. I've made it from about six different veg oils and pork fat. The animal fats have a little more BTU's per gallon but the cold flow properties are alot worse.
__________________
2004.25 F250 CC Powerstroke on B100, 220K miles
1992 F350 CC SRW 4x4 Cummins powered, on B100
Biodiesel maker
http://community.webshots.com/user/b...host=community
  #3 (permalink)
Old 04-19-2008, 10:41 PM
The reason the OEMs don't endorse more is they are still doing long term testing and they know that the quaility of bio on the market is all over the map. They figure they're engines will continue to run on 2% of anything. Be it bad underconverted biodiesel or Orange Tang.
__________________
Biodiesel maker
  #4 (permalink)
Old 04-21-2008, 08:41 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Quote:
Actually they are waiting for ASTM to finish the standards for blends over 5% BD. Then we have to get all states to require adherence to those standards.
But, you are absolutely correct in saying the quality of BD is all over the map. Infact that is one arguement for hombrew if it sux you have no one to blame but yourself. Making quality homebrew is pretty easy if you pay a little attention to detail and don't shortcut.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
