Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Modular V10
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-14-2008, 11:19 AM
oldkountryboy is starting off with a positive reputation.
01 v10 running like crud
alright guys i need some help on where to start here
background 2001 v10 110,000 miles, k&n , gibson headers, true duals,
i had been running a superchips 1715 programmer but did not notice much difference so i sold it after i put the truck back to stock and it ran great a few months
now it idles fine and around town it seems to run good but when i get on the road it runs like crud you can feel it hesitate and not want to pull
but i do not get a check engine light
so where should i start
i replaced the plugs and boots about a month before i took the programmer off
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-14-2008, 12:29 PM
also my fuel mileage went from 10-12 down to 6-7mpg
  #3 (permalink)
Old 04-14-2008, 12:54 PM
bigblock_drock is starting off with a positive reputation.
clogged fuel filter? maybe clean the MAF also.
__________________
The Fleet
1994 Mercury Grand Marguis 4.6 145,000 miles
2005 F-350 6.0 44,000 miles
2008 F-150 5.4 9000 miles
  #4 (permalink)
Old 04-14-2008, 02:22 PM
juterbock is starting off with a positive reputation.
I replaced the fuel filter and went from 12 to 13.5 MPG on my 108k milage 2001 V10. I've got a new set of O2 sensors in the truck and plan to clean the MAF again and then reset the computer and see what I get on this tank. Spark plugs are in the works either this coming or the next weekend.
__________________
Horsepower is how hard you hit the wall, torque is how much of the wall you take with you!
2001 F-250SD V10-BSEG 5-Speed Stick, Manual 4X4, 4.30LS SC SB XL - Bilstein HDs
1999 F-150 V6 Auto XLT - Traded
1988 F-250 351W Auto 4x4 - Sold
1983 F-600 Bucket Truck - Sold
1961 F-100 292 Y-8 3-Speed Unibody, Custom Cab - Gave Away
  #5 (permalink)
Old 04-14-2008, 02:37 PM
rvpuller is starting off with a positive reputation.
The first thing I would do is the fuel filter and then the MAF.
Denny
__________________
2000 F350 Lariat SC DRW V10 4.30 Gears BrakeSmart
Air Lifts 4X2
2003 HH Premier 35 FKTG
BSEG started 4/15/2000
  #6 (permalink)
Old 04-14-2008, 06:18 PM
thanks guys, i will change it in the morning
  #7 (permalink)
Old 04-14-2008, 06:27 PM
Skoda is starting off with a positive reputation.
please do report back with your results, I to am running 6 mpg and not one bit happy about it
__________________
99 F-250 Lariat V10
***Looking for a black grill 05-07 some nicks and scratchs exceptable***
05 upper bumper valence
Tow mirrors
05 Head lights
Ebay Headers
SCT LiveWire from 5 star tunning
Dual 16" coolling fans
Top end rebuild
ARP head studs
  #8 (permalink)
Old 04-14-2008, 07:19 PM
well i quit driving mine everyday a few months ago, i got lucky on a deal for a 92 mustang with a 4 cyl for 500 bucks, so i have been saving over 200 a month by driving the mustang i love my truck and my v10 but with 44s and gas being as high as it is and i was using at least a tank a week and sometimes more
needless to say it has paid for itself several times over
  #9 (permalink)
Old 05-10-2008, 08:31 PM
sorry it took so long to get back to you guys, thanks for the ideas but the fuel filter and cleaning the maf didnt help, i borrowed a friends temp gun and checked the headers after it warmed up for about 15 minutes and the passenger side bank is not running the same as the drivers side, drivers side temps right at the exhaust on the headers was running from 230 degrees C to about 275C, and the pass. side was anywhere from 90 C to 150 C
the only two things i can think of would be the O2 sensor and maybe a head gasket
can yall think of anything else that would cause one bank to be so much different than the other ?
  #10 (permalink)
Old 05-10-2008, 08:48 PM
I'd pull out the good old obd2 scanner, check for any codes, if your lucky it will be one or some cop's, if thats not the problem then I'd reccomned doing a compression check ( if theres a miss fire due to a blown head gasket there will be a code present**even though the check engine light is not on**)
A possible quick tip would to manualy turn your motor over, and listen for escaping air, take off your pcv valve, radiator cap and see if theres bubles coming from either.
Hope its nothing serious, best of luck
Skoda
__________________
99 F-250 Lariat V10
Tow mirrors
05 Head lights
Ebay Headers
Top end rebuild
ARP head studs
  #11 (permalink)
Old 05-16-2008, 07:12 AM
well here is an update guys, went to 2 different parts stores and neither would try and read the codes because the check engine light is not on
so i went with my gut and bought a passenger side O2 sensor and man a huge difference
it is still not perfect so i am going to order another O2 for the drivers side and 10 COPs and thinking of putting in new injectors, i have a spare set i think i will put new filters and o-rings on all that should put me running smooth and strong again
thanks again for the help and advice guys
  #12 (permalink)
Old 05-19-2008, 08:04 AM
That is probably some serious overkill to replace all of your COP's and injectors. I've never done it but they say to run Techron through your fuel system and it will clean out the injectors quite nicely. And if you think one of your COP's is bad, get the OEM replacements (1 of them) and then swap it out with each of them. If the engine runs better after a particular swap you know you found a bad COP.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
