Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-14-2008, 11:22 AM
lettk is starting off with a positive reputation.
4.0 OHV for 4.0 SOHC???
01 sportTrac with SOHC, 152k miles w/5spd.
a couple months ago i replace the front cam cassette - using the special ford tool. ran just fine.
yesterday while pulling a hill on the fwy - it started to sound like pre-igntion (marbles in a can) - then the power dropped of and we coasted to shoulder.
i'm ready for a new engine...
Can i swap a 4.0 OHV in place of the SOHC?
is this a straight bolt-in?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-14-2008, 02:51 PM
floydguy is starting off with a positive reputation.
the best way to check is to see how everything is on the donor truck. install it the same way on your sport track.
  #3 (permalink)
Old 04-14-2008, 04:58 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
What is your smog check situation? The pushrod motor was not offered in '01 (afaik). You would not be able to do this in CA, not sure how AZ deals with older engines....
I'd fix the sohc motor.
  #4 (permalink)
Old 04-20-2008, 09:26 PM
Lead Head is gaining momentum as a positive member of FTE.Lead Head is gaining momentum as a positive member of FTE.
the 4.0 OHV is not a straight bolt in, you will need a new PCM, as well as new wiring harness. Also be prepared for a significant drop in power.
  #5 (permalink)
Old 05-09-2008, 11:55 AM
TheHandyman is starting off with a positive reputation.
It would be easier to stick another OHC engine in it. It may cost the same too because you'd about have to buy a whole donor truck to go backward and covert to an older OHV engine.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
