factory fiberglass truck bed panels!?!?!? - Ford Truck Enthusiasts Forums
Old 04-14-2008, 04:55 AM
GETDOWN!!!'s Avatar
GETDOWN!!! GETDOWN!!! is offline
GETDOWN!!! is gaining momentum as a positive member of FTE.
just yesterday i was offroading and later inthe day i discovered my driver side truck bed panel was cracked....this blew me away cause i though i had steel panels. but apparently i have fiberglass casue steel wouldnt of done that. i know my tail-gate is steel but whats the truck bed fendors aftermarket? someone shed some ligh on thiss issue. i cant imagine FORD would make fiberglass fenders an otion or standard on my truck.
i own a 2001 f.150 xly lariat 5.4 v8 supercrew. and the truck bed has the lights rounded off. the curved lights, not the regular rectangle ones.
Old 04-14-2008, 07:53 AM
mel2000f150 mel2000f150 is offline
mel2000f150 is starting off with a positive reputation.
The sidebeds are fiberglass.
Old 04-14-2008, 08:25 AM
12secondstang's Avatar
12secondstang 12secondstang is offline
12secondstang is starting off with a positive reputation.
My buddy was pulling a car trailer. He backed up and got it too sharp and flexed the bumper into the panel and cracked it the whole length top to bottom. He too was shocked to see the glass sides. The truck only had 1400 miles on it.
Old 04-14-2008, 08:33 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
its just on the supercrews and the step sides.... the regular sided trucks (fleet) have steel...
Old 04-14-2008, 10:44 AM
ggarrahan ggarrahan is offline
ggarrahan is starting off with a positive reputation.
Well remember, they won't rust. My 2003 stepside does indeed have plastic bed sides. The inner bed panels are all steel, however.
Old 04-14-2008, 10:58 AM
fiberglass bedsides, not plastic, and what inner pannels are you talking about, the bed itself is steel, but there is no inner fender... the fiberglass bedside bolts to the steel bed underneath the plastic bed rail caps.... and then theres a few monts down at the bottom corrners of the fiberglass bedside to
Removing step side bolts from side panels bcamill 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 03-27-2014 11:29 AM
Steel vs Fiberglass jwrussell 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 04-06-2011 09:12 PM
Steel or FiberGlass?!? Good-Deal1023 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 09-04-2010 05:43 PM
Prerunner opinions... broncoderek 1987 - 1996 F150 & Larger F-Series Trucks 27 08-07-2009 04:36 AM
fiberglass or steel running boards reed1951 1948 - 1956 F1, F100 & Larger F-Series Trucks 33 11-30-2007 08:09 PM
Tags
bed, fiberglass, ford, panel, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
