98 F150 4.6l Towing/payload capacity? links? - Ford Truck Enthusiasts Forums
Old 09-04-2001, 03:29 PM
jdaugela jdaugela is offline
jdaugela is starting off with a positive reputation.
What is a 1998 F150 (with trailer packager) 4.6l V8 towing and payload capacity?
Does anyone know any good links to get the full specs? I am thinking of buying one. Is a 99 or 2000 a better idea?
This is my first truck and I don't plan on hauling much - just occasionally pulling my boat with a camper. Can it handles this?
Old 09-04-2001, 06:37 PM
Torky Torky is offline
Torky is starting off with a positive reputation.
97 info, 98 probably the same. 4.6L automatic w/towing package included 3.55 rear end, towing was 7000 lbs. for 4X2 SuperCab, 7200 for Regular Cab. A 4X4 knocks 400 lbs. off of towing capacity on both cabs. A manual trans cuts towing at least in half.
Payloads from 1700 to 1965 lbs. depending on what cab, what bed length. Regular cab had some optional payload packages that went over 2000 lbs, don't know how common those are, maybe not very.
If you have a particular configuration in mind, I can look it up.
Old 09-05-2001, 11:57 AM
Thanks for your help.
Where can I get the following info?
I would like to know GCWR, GVWR, payload,towing and Axle ratings for each one:
1. 1998 F150 XLT Supercab Shortbox 4.6L V8 4x4 (gears=? regular most common ratio probably?)
2. 2000 F150 XLT Supercab Shortbox 4.6L V8 4x4 3:55 gears
3. 1998 F250 XLT Supercab Shortbox 5.4L V8 4x4 (gears = ?)
4. 1999 F250 XLT Supercab Shortbox 5.4L V8 4x4 (gears = ?)
- Trucks are all automatic.
Knowing these numbers would be excellent. My truck purchase descision would be made MUCH easier!
Is there a site with this info?
All your help is very much appreciated. Thanks.
Old 09-05-2001, 10:10 PM
I can only help on your scenario #1, 4.6L auto 4x4 Supercab, but with 1997 info, should be same for 1998.
With 3.55 axle GCWR is 11,500, max trailer is 6,600, GVWR is 6000.
With 3.08 axle (I would avoid 3.08!) GCWR is 10,000, max trailer is 5,100, GVWR is 6000.
Payload on the S/C 4x4 is only 1,365 minus people and opt. equipment. Choosing 4x4 drops towing by 400, and payload by 400 vs. the 4x2 ratings.
If you back off of 4x4 down to 4x2 to get the power, mileage, towing and payload back, you probably want the Limited Slip rear axle for slippery boat ramps.
I don't know of any site that lists the information you want. If people with newer trucks have a brochure, they could look it up.
Good luck with your hunt!
Old 09-27-2001, 04:24 PM
GeorgeEh GeorgeEh is offline
GeorgeEh is starting off with a positive reputation.
Here is the best source for all ford towing specs. good luck.http://fordtruck.fordtraining.com/f150/html/spcfrm.htm
Old 09-28-2001, 02:37 PM
Thanks for the link!! Excellent info! MUCH APPRECIATED. I am going to test drive the truck I am thinking of buying in 2 hours! ... now I know the specs and don't have to trust the salesman.
Have a cold on one me.
John
Old 09-29-2001, 10:53 AM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
Trailer Towing Capacity awonboys 2004 - 2008 F150 9 12-29-2013 10:52 PM
Payload vs Engine Size PrinceValium 2009 - 2014 F150 18 10-29-2012 09:55 AM
payload and towing info No.Va.F150 2009 - 2014 F150 10 12-17-2011 12:45 PM
F150 5th wheel capacities? surfcitywriter Fifth Wheel & Gooseneck RV Towing 16 07-04-2008 01:48 AM
payload, towing and fuel capacities of 2004 F150 jalbs 2004 - 2008 F150 1 01-08-2003 01:39 PM
Tags
150, 1997, 1998, 46, 4x4, 7000, 98, 99, capacity, f150, ford, payload, tow, towing, trailer, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
