Virtually all '94 5 liter CWs are going to have the 4R70W (AODE) in them. There may be a few stray E4ODs out there but they are VERY rare.
Quote:
Originally Posted by Club Wagon
Think the '90 Towncar has the same AOD vacuum-no button
Note: AOD's do not use a vacuum modulator. They use a TV cable.
Someone did tell me its easier to put an AOD into a newer CW than vice versa. No idea how much easier, or even if its true.
You could put an AOD in a van that had an AODE but you would have to completely change the throttle linkage at the throttle body to be able to attach the TV cable. This would be a PITA.
To install an AODE (4R70W) in place of an OE AOD, you would have to swap the entire PCM and wiring harness to provide the electronics to drive the AODE.
Any pre '97 4R70W (AODE) with the long tail shaft and a 5.0 bellhousing will work in your van.
