I know this is more or less a preference thing...but is it worth the extra $170 for the ceramic coated JBA headers?
I'm lookin at the 1679S ($373.95) or the 1679SJS ($540.95) from autoanything, doesn't look like anyone can beat their prices.t
Also, i've asked before, but how is the hardware and gaskets that comes with JBA??? Should i be looking at other brands of those?
__________________
Semper Fi,
Rob
HMCS(FMF/AW)
USNR (now)
just my experience--
i have cer. coat headers (about 1.5 yrs old)and rust is comin thru, they may have seen 2000 miles since installed (not a dd) and it is stored inside
I was always lead to believe that the ceramic coating was for heat retention IN the exhaust stream. . .the inside isn't treated and can/will rust through. Especially if you don't drive it. When it sits moisture collects and just sits inside the headers and rusts them out. Starting it up regularly clears out the moisture and the carbon coating the exhaust leaves might even help prevent rust damage
Speculation on my part, I really don't know
But I'd say Stainless for longevity, and ceramic coat them to keep under hood temps down
__________________
Steve
2004 F150 STX
1978 F-250 4X4
1987 F-250 4x4 VIRGINIA CHAPTER Virginia Chapter Website
My brother (accidentally) got ceramic coated Dynomax headers for his F150. After less than a year the ceramic coating was falling off the lower part of the headers.
Also, I bought a log manifold for my Thunderbird when I was building the engine and paid $100 extra for ceramic coating (and it was coated inside & out). It started to rust after less than a year also, now I've had it for 3 or 4 years and it's got rust all over it.
I haven't been very impressed.
__________________ 1994 F250 XLT-Reg cab, 4x4, 5 speed, 7.3 IDI Turbo, manual hubs, ATS upgrade, 4" exhaust w/Hooker MaxFlow, custom intake, pyrometer & boost gauge, turned up fuel http://www.cardomain.com/ride/3055099 1987 Thunderbird Turbo Coupe-Lots of fun stuff to make it go fast & take corners http://www.cardomain.com/ride/306349
Well, the ceramic coating does help keep the heat down, but remember, stainless steel is a very poor conductor of heat itself. Which is probably part of the reason the stainless steel is uncoated.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
Ceramic is easier to clean, and will help keep underhood temps down compared to stainless.
The key with coatings is to keep from scratching it. The slightest scratch can let in moisture and rust and make the whole part look bad.
Im not talking about little scratches, I mean bumping the part against something during install or some kind of hard hit and not noticing the coating came off.
Of course there is always the quality of the coater/coating to be aware of also.
I have experience with ceramic coatings and would not hesitate to buy it again.
__________________
1964 F100- Gonna see boost
1998.5 Ford Contour- Many mods
You could always have the stainless ones ceramic coated.
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
I have never saw a set of ceramic coated headers that will not eventually rust, peel or look crappy eventually. I would get the stainless headers. You can always get a can of Duplicolor or similar 1200 deg ceramic header paint and paint the headers with it. Prep the headers good and scuff up with an abrasive pad like Norton Beartex. I use the Duplicolor paint to keep after my Thorley headers. My Thorley header are a high dollar set of headers with a good cermaic coating and they still get specs of rust in short order. The header paint works good and is cheap and it has some ceramic in it. A ceramic coating is just a glorified paint.
Ceramic coating should be on the inside and outside for best wear..quality job....I have a set of headers that have lasted for 15 years now....you do lose the shine after a while from the heat...but still better then paint or bare metal.....just my two cents
