Go Back   Ford Truck Enthusiasts Forums > Diesel > 2011 6.7L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2011 6.7L Ford Diesel Discuss the upcoming Ford Powerstroke 6.7L diesel engine
Is F-150 Still King?
  #91 (permalink)
Old 05-09-2008, 10:02 PM
tex25025's Avatar
tex25025 tex25025 is online now
tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE.
Quote:
Originally Posted by F350-6 View Post
A word of warning about your truck Tex. The 6.0's taste better than the 7.3's. I've had 2 06's & 1 07 taken down by squirrels getting into wiring. Never had that problem with any of the 7.3's.
Not a problem, if my truck isn't on the road running it's in the garage resting. Thanks for the heads up though I wouldn't have thought of it, although they do get in my tractors on occasion.
As to the emmissions stuff, I think they skipped my truck on the assembly line for some strange reason I just don't have it on there. Who knew, huh.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
Suncoast Heavy Duty Torqshift Rebuild
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #92 (permalink)
Old 05-09-2008, 11:49 PM
BigF350 BigF350 is offline
BigF350 is starting off with a positive reputation.
Quote:
Originally Posted by Big Bad View Post
Those 5.0 blocks weren't half as durable as the Modular blocks, FYI.
The Lightning 5.8L with the tubular GT40 intake, GT40 heads, a camshaft out of one of the marine crate engines made less horsepower AND torque than a run-of-the-mill 1999+ 5.4 2V.
I could not agree more with you about the Modular Blocks. IMO. They are tough and way more efficient than any 5.0 or 5.8 in it's day..
  #93 (permalink)
Old 05-10-2008, 10:29 AM
preppypyro's Avatar
preppypyro preppypyro is offline
Posting Legend
preppypyro is a splendid one to behold preppypyro is a splendid one to behold preppypyro is a splendid one to behold preppypyro is a splendid one to behold preppypyro is a splendid one to behold preppypyro is a splendid one to behold preppypyro is a splendid one to behold
Ive had the 4.6 and i have a couple of 5.0's. They are both pretty good motors. I would say the 4.6 seems to be every bit as good as the 5 liter was, if not more. You really need to own/drive one for awhile to really appreciate it though!
__________________
$Sheldon$
2003 F-250 supercab shortbox 4x4 lariat
~Everythings legal man as long as ya dont get caught~
  #94 (permalink)
Old 05-10-2008, 03:55 PM
Big Bad Big Bad is offline
Big Bad is gaining momentum as a positive member of FTE. Big Bad is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by tex25025 View Post
It wasn't a total disaster, I'm not disappointed one bit with my 6.0. Y'all 7.3 guys are stuck in the past, but I guess if your happy then so be it, I just refuse to settle.
If the 6.0 was stone reliable like the 7.3, I would agree with you. But it isn't, and the 7.3 seems to get slightly better mileage to boot.
I would trade some horsepower and NVH for better mileage and a reliable/easy to work on truck.
The 7.3 is/was an awesome engine.
  #95 (permalink)
Old 05-10-2008, 04:36 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
The 7.3 isn't stone reliable either, there is quite a few cases of them melting holes in pistons, blowing HPOP, injectors, etc..
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #96 (permalink)
Old 05-10-2008, 05:03 PM
The 7.3 is just about as stone reliable an engine you can ask for. Please give me a single, solitary example of a mass produced Otto-cycle engine design that has never experienced a melted piston (for whatever reason) or fuel injector/fuel delivery problems. Name just one.
  #97 (permalink)
Old 05-11-2008, 06:06 AM
IB Adrian's Avatar
IB Adrian IB Adrian is offline
Administrator
2005 Ford Falcon
My Garage
IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation
I have never known an L Series Mercedes Benz to have either... well never the former, and not fuel injector problems for at least a million miles.
__________________
Adrian
FTE Guidelines
Quote:
Originally Posted by WhëëlMĺ1
... he is a mouthy broad.
  #98 (permalink)
Old 05-11-2008, 01:13 PM
Quote:
I have never seen a 7.3 with melted pistons that was in stock form.... Yes they have had the odd injector problem. But tell me of an engine gas or diesel that has not!!!! The only way a 7.3 would melt pistons is if you are running a chip or programer and are not watching your egts.... IMO..
  #99 (permalink)
Old 05-11-2008, 02:52 PM
Quote:
Theres quite a few posts in the 7.3 sections that would like to disagree with you. Even members here have said you can easily burn the pistons on a stock 7.3
The point is the 7.3 has had its share of issues too. UVC Harness corrosion, shorting out, etc..The crackling #8 injector, EBP sensors getting plugged up, early IDM problems, romping, and a lot more common issues. Most of these problems were worked out in the later years, but guess what? Same for the 6.0. The 6.0s were quite reliable power plants by 2006
__________________
- Ian
  #100 (permalink)
Old 05-11-2008, 04:48 PM
tex25025's Avatar
Don't all y'all 7.3 guys always have to keep a spare cps deal with y'all because it's always going out? Thought I keep hearing about something like that.
__________________
Fluidampner
Headstuds
FASS 150/180
  #101 (permalink)
Old 05-11-2008, 04:53 PM
F350-6's Avatar
F350-6 F350-6 is offline
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
Naw we don't have to do that. We can just pretend we're in a Chevy & walk. Actually the CPS doesn't seem to go out after you throw a spare in the glove box.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 310,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #102 (permalink)
Old 05-11-2008, 07:17 PM
Even the later 6.0s were not as reliable as the 7.3, nowhere near it in fact. Ford's overall warranty costs were through the roof 2004-2006 due primarily to the 6.0. Ask any Ford diesel tech which is the more reliable mill, and there will be no hesistation before they respond with "the 7.3." The 7.3 is a far more reliable engine and it is far easier to work on to boot.
Yes, the 7.3 had it's common issues, but they in no way compare to the 6.0 issues in severity or frequency. Any claims to the contrary are the result of 1 or 2 possibilities: 1. delusion 2. ignorance on the issue.
Back to the 6.7...
  #103 (permalink)
Old 05-11-2008, 07:58 PM
I'm not tryign to say the 7.3 had more problems, I just hate it when people make the 7.3 out to be this godlike motor that can go 6 million miles on the original oil while having 10 lbs of sand dumped in the intake every 5 seconds.
But yes, back to the 6.7..
Anyone else notice the current trend in diesels going the wrong way, back to large displacement engines? The 5.9 Cummins went to 6.7, 6.0 PSD went to 6.4, then is going to go to a 6.7. All in the name of emissions too. Seems like the EPA really needs to look more into these things before they make the laws.
__________________
- Ian
  #104 (permalink)
Old 05-11-2008, 08:49 PM
preppypyro's Avatar
Posting Legend
We find a cps is lighter, and fits better in the glove box then a set of head gaskets and a turbo
__________________
$Sheldon$
  #105 (permalink)
Old 05-11-2008, 08:53 PM
preppypyro's Avatar
Posting Legend
Its funny they are getting to be alot bigger engines, but thats the whole hp/torque wars for ya!
I still dont get why a engine that uses more fuel would be "better for the enviroment".
Those epa guys need to give htey head a shake!
__________________
$Sheldon$
Tags
30e , power , stroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
