Go Back   Ford Truck Enthusiasts Forums > Diesel > 2011 6.7L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2011 6.7L Ford Diesel Discuss the upcoming Ford Powerstroke 6.7L diesel engine
Is F-150 Still King?
  #61 (permalink)
Old 04-26-2008, 10:41 AM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE.
Quote:
Originally Posted by parkland View Post
Ford needs the engine to run like a gasser, and the ford parts and programming is what causes the problematic behavior.
Nope, international versions of the 6.0 also have had the head bolt problem even though they are pulling in less horsepower then with the Ford programming.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
Suncoast Heavy Duty Torqshift Rebuild
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #62 (permalink)
Old 04-27-2008, 01:31 PM
Dustball8504's Avatar
Dustball8504 Dustball8504 is offline
Wooooooo!!!
Dustball8504 is starting off with a positive reputation.
Wow, I like how a forum designed to talk about a new 6.7L Ford Diesel engine has turned out to be a pissing contest over what "old" Ford motors are better. This thing has went from light duty car and truck engines (5.0, 5.8, 4.6, 5.4) to a dispute over the Powerstroke lineup (7.3, 6.0, 6.4). Personally I think every one of these motors are good in their own way, some have advantages over the others and such but they are still good running, long lasting motors. What is the 6.7L anyway, maybe we can get back to the topic, are their any numbers released on it yet?
__________________
2004 F250PSD Gray Sport - 403.5rwhp 777.0rwtq 13.96@94.65mph
1990 Ford Mustang LX - 03 Cobra powered!!
2009 VW Jetta TDI - 45mpg...
1969 AMC SC/Hurst Rambler - Getting Restored
http://www.youtube.com/dustball8504
  #63 (permalink)
Old 04-27-2008, 01:52 PM
tex25025's Avatar
Quote:
Unfortunately, until you have something out in the public to where people can buy it, this is what's going to happen because all people have is speculation until something finally shows up to actually review.
__________________
Fluidampner
Headstuds
FASS 150/180
  #64 (permalink)
Old 04-27-2008, 02:29 PM
BLK94F150 BLK94F150 is offline
BLK94F150 has a great reputation on FTE. BLK94F150 has a great reputation on FTE. BLK94F150 has a great reputation on FTE. BLK94F150 has a great reputation on FTE.
Welcome to a forum. I don't think any thread actually stays 100% on topic.
Mike
__________________
Confusing people's opinions with facts here since 09-30-2002
  #65 (permalink)
Old 04-27-2008, 05:25 PM
Big Bad Big Bad is offline
Big Bad is gaining momentum as a positive member of FTE. Big Bad is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by scottman70 View Post
The engine design could have been bored stroked, different intake, heads etc....Those 5.0 and 5.8 engine blocks were very durable and could have been retained and upgraded with better hp and torque and mpgs
Those 5.0 blocks weren't half as durable as the Modular blocks, FYI.
Quote:
.....Although had the 5,0 roller motor been put into the F-150 that would have had been plenty of power!!
The Lightning 5.8L with the tubular GT40 intake, GT40 heads, a camshaft out of one of the marine crate engines made less horsepower AND torque than a run-of-the-mill 1999+ 5.4 2V.
  #66 (permalink)
Old 04-27-2008, 06:08 PM
78F150XLT 78F150XLT is offline
78F150XLT is starting off with a positive reputation.
if your compareing the gen 1 lightning to the gen 2 lightning, OF COURSE THE 5.4 will have more hp/tq. its got a blower... if you put a plower ona 5.8, you'll have more power then the 5.4, havnt you heard no replacement for dispalcement. haha make them equal and it will prove then old school windsor will be better. how come the 5.0 and 5.8 stangs are runnin faster times then 4.6's and 5.4's?
Enough with the gas motors in the desiel forum... k? As for ford making their own desiel, i hope it actually happens... it would be a good time to show waht ford really is made of if they can produce thier own block and run with the cummins/duramax's out there in the desiel world.
__________________
95 F150 Reg. Cab, Long Box, 4X4, Customd
02 F250 Lariat Ext. Cab, Short Box, 4X4.
6.5 Procomp lift, 37/13.5/20 nitto mud grapplers, Garret turbo, 4inch Turbo back exhaust, Injectors, fuel pump, AFE Brute, NADP Tranny, ZEX Nitrous, NO CHIP!
  #67 (permalink)
Old 04-27-2008, 06:24 PM
Quote:
Obviously I'm not comparing the gen 1 Lightning to the gen 2, since the gen 2 never came with a 5.8.
1995 F150 5.8: 210 HP/328 TQ
Gen 1 Lightning 5.8: 240 HP/340 TQ
1999 F150 5.4 2V: 260 HP/350 TQ
Gen 2 Lightning S/C 5.4: 380 HP/450 TQ
The Gen 1 Lightning had a tubular GT40 intake, GT40 heads, and a more aggressive marine cam and still made less horsepower and torque that the run-of-the-mill PI 5.4.
Put a blower on a stock non-GT40 5.8, and it's still a turd.
Put a blower running 10 psi on a stock Gen.1 Lightning 5.8 engine, and it still makes less horsepower to the wheels than my 4.6 4V with stock H/C/I.
They aren't.
It's happening, 100% set in stone. Built in Chihuahua, Mexico, 4V-per-cylinder, direct injection, urea injection, TT.
I believe it will do more than run with them.
  #68 (permalink)
Old 04-27-2008, 09:06 PM
bluedevil3758 bluedevil3758 is offline
bluedevil3758 is starting off with a positive reputation.
i saw 400hp/3500 and 700/16 or 1800 rmps somewhere
__________________
1999 ranger 3.0l 4x4 4.10
2005 f150 2wd 5.4 scab 3.73s
  #69 (permalink)
Old 04-27-2008, 11:00 PM
LaredoF350's Avatar
LaredoF350 LaredoF350 is offline
LaredoF350 is gaining momentum as a positive member of FTE. LaredoF350 is gaining momentum as a positive member of FTE.
I never had a 7.3 but some friends have them. They appear to be pretty reliable. I have a 6.0 thats been problematic, but with the ARP's, EGR cooler exhaust gas blocker, and custom tuning it runs very well now - in a more refined and way more powerful way than any of my friends' tuned 7.3 engines do. Would I ever trade my 6.0 for a 7.3? Never! The 7.3 is just getting dated in refinement but the guys who love them are justified in doing so because they make some reliable power. The 2008 with the 6.4 makes mine feel like an old clunker in the same way my 2003 does to the previous years with the 7.3.
Back to the thread - I hope the new engine works well. The Dmax appears to have the edge in terms of mileage and reliability for now. I have no experience with the new Dodge diesel 6.7 offering.
__________________
2008 F-250 Lariat SRW 4x4 CC SWB ...
... 6.4L & Torqshift w/3.73
... Dark Stone Metallic / Pueblo Gold
... Readylift levelling kit w/caster cams
... Toyo MT 35-12.5-18
BIG$HOW --«Õ¿Õ¬»
  #70 (permalink)
Old 04-27-2008, 11:23 PM
97nukeford's Avatar
97nukeford 97nukeford is online now
Nebraska Chapter LDR
2006 Ford F-250
My Garage
97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of
I look forward to Ford designing there own diesel. If nothing else, they'll have to be much more accountable for the way it performs. By the time I'm ready to trade in my 6.0, I hope Ford has this engine all worked out.
__________________
Pat W.
Nebraska Chapter Leader and Official #2 Slackmaster!
2006 F-250/ 1997 F-150/1967 F-100
1967 F-100 Project
GO HUSKERS!!
CLICK HERE TO JOIN THE NEBRASKA CHAPTER!
  #71 (permalink)
Old 04-27-2008, 11:34 PM
If you do a several thousand dollars of work and totally blow the warranty, the 6.0 can put out crazy power and be pretty reliable, but it still can't do all the things that it was meant to do. It doesn't have pilot injection like the early 03s and call me crazy, but I'm sick of diesel clatter. The turbo lag seems really bad as well considering that the VGT turbo that caused countless problems was supposed to really help with lag.
The 6.4 is a really sweet engine. The numbers that the tuners are putting out on the stock drivetrain are insane.
I hope that the 6.7 gets the peak torque back down to ~1600RPM. When you've only got 3500-4000RPM to play with, 2000 is getting up there for an engine that is supposed to have power down low.
Mike
__________________
  #72 (permalink)
Old 05-04-2008, 12:43 AM
85Diesel_F250 85Diesel_F250 is offline
85Diesel_F250 is starting off with a positive reputation.
i read in autotrader that the 6.4 only gets 10mpg..... is this true? i thought my 6.9 gettin 13.7 was bad. I know nothing about the 6.4 i just wondered if that was true
  #73 (permalink)
Old 05-04-2008, 08:31 AM
tex25025's Avatar
Quote:
I have heard of some getting 12 and maybe a few tenths more then 12, but 12 seems to be it's high point for a stock 6.4. I don't know what they are getting for those that have removed the dpf and all the other epa "stuff".
__________________
Fluidampner
Headstuds
FASS 150/180
  #74 (permalink)
Old 05-04-2008, 10:02 AM
Jonas1022's Avatar
Jonas1022 Jonas1022 is offline
Jonas1022 is starting off with a positive reputation.
Quote:
Originally Posted by origcharger View Post
Ford and International have not been playing well together lately. The 6.4 liter V8 is not going away, it just may not be found between the fenders of a SuperDuty in the future.
IMO, this is the case.
__________________
1994 Ford F-150 XL
2000 Escort ZX2 Sport (deceased)
2001 Mustang Bullitt GT
2002 Chrysler PT Cruiser
2008 Mazda Tribute iSport
  #75 (permalink)
Old 05-05-2008, 08:13 PM
SUPERDUTY_untouchabl's Avatar
SUPERDUTY_untouchabl SUPERDUTY_untouchabl is offline
SUPERDUTY_untouchabl is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by tex25025 View Post
I have heard of some getting 12 and maybe a few tenths more then 12, but 12 seems to be it's high point for a stock 6.4. I don't know what they are getting for those that have removed the dpf and all the other epa "JUNK".
I fixed that for you...
__________________
-Josh
04 F150 4.6l Gryphon Powered 2wd reg cab XL 3:55 LS SISO Flowmaster S40 NCD Customs 2.5" Leveling Kit Burner High Power Fog Lights 285/70/17 BFG A/T KO's
Tags
30e , power , stroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
