Go Back   Ford Truck Enthusiasts Forums > Diesel > 2011 6.7L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2011 6.7L Ford Diesel Discuss the upcoming Ford Powerstroke 6.7L diesel engine
Is F-150 Still King?
  #46 (permalink)
Old 04-20-2008, 01:49 AM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a good reputation on FTE. biz4two has a good reputation on FTE.
Arrow
Quote:
Originally Posted by scottman70 View Post
The only motor I really miss is the 5.0! I had a GT mustang (1986) that thing was fast.
The 5.0 was a car engine. Was never a good truck engine...unless in a light weight F150...and even then a complete slug...in OEM form.
I agree...in a Mustang (light car) it was a fine motor, but never belonged in an F-Series truck...IMHO. My Dad owned a 1990 F150 4x4 with a 5.0L...and that thing got 14mpg highway with no load. Sorry...but the 5.0L not the BEST engine FORD ever decided to put a in a truck.
Forgetaboutit...talking about the modular engines. Once again...IMO...the 5.4L and 6.8L V10 are in another BETTER class altogether.
Just my .02 here...
biz
__________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
  #47 (permalink)
Old 04-21-2008, 02:37 AM
78F150XLT 78F150XLT is offline
78F150XLT is starting off with a positive reputation.
it was a hit and miss with the 5.0's in the f150's.. pre94-95 when they didnt have the roller cam set up they were harsh on fuel. when they changed over to the roller cam set up it improved way more... i out pulled a 5.4L with my 5.0L on dry pavement many of times to shut the guy up about him bragging it has so much mroe power... the 5.4s have a higher failure rate the the5.0's or 5.8's, personally ford shoulda stuck with the windsor blocks.
Wasnt the 6.4L desiel originally a marine based motor? I hope, if the 6.7 is true, thats its alot like the old 7.3 in power wise and reliability... id for sure buy one over that 6.4
__________________
95 F150 Reg. Cab, Long Box, 4X4, Customd
02 F250 Lariat Ext. Cab, Short Box, 4X4.
6.5 Procomp lift, 37/13.5/20 nitto mud grapplers, Garret turbo, 4inch Turbo back exhaust, Injectors, fuel pump, AFE Brute, NADP Tranny, ZEX Nitrous, NO CHIP!
  #48 (permalink)
Old 04-21-2008, 10:18 AM
scottman70's Avatar
scottman70 scottman70 is offline
scottman70 is gaining momentum as a positive member of FTE.
My point was not that the 5.0 should be the exact motor in the F-150. The engine design could have been bored stroked, different intake, heads etc....Those 5.0 and 5.8 engine blocks were very durable and could have been retained and upgraded with better hp and torque and mpgs.....Although had the 5,0 roller motor been put into the F-150 that would have had been plenty of power!!
  #49 (permalink)
Old 04-22-2008, 02:28 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is online now
Redneck Has Been
rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE.
[quote]
Just my .02 here...
the 5.0 wasn't really a good car engine,except for something 3000 lbs or lighter,the 5.8 was a little better
the 4.6 was much more efficient and longer lasting than the 5.0 or 5.8
I have had both 5,0 and 5.8 in f-150s and niether will perform or last as long as a 4.9 I-6
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install, DooDad???=(dfuser ram air)
'98 Grand Cherokee, '86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
  #50 (permalink)
Old 04-24-2008, 01:44 PM
BLK94F150 BLK94F150 is offline
BLK94F150 has a great reputation on FTE. BLK94F150 has a great reputation on FTE. BLK94F150 has a great reputation on FTE. BLK94F150 has a great reputation on FTE.
I've had the 5.8 in a 94 F150 regular cab 4x4 and the 5.4 in a 2000 F150 Supercab 4x4 and the 5.4 is much more powerful and fuel efficient. The only downside is that externally, it's huge.
Lately though, Ford has been going through diesels like a crack junkie. After the good old 7.3 they had the 6.0 for 4 troublesome years, the 6.4 for what looks like 2 and now whatever comes next.
GM has had the 6.6 since 2001 and it's still soldiering on with minor tweaks here and there and some upgraded components like VGT and DPFs. Dodge has had the 5.9 forever and now the 6.7.
Mike
__________________
Confusing people's opinions with facts here since 09-30-2002
  #51 (permalink)
Old 04-24-2008, 02:29 PM
BowTieHatr BowTieHatr is offline
BowTieHatr has a very good reputation on FTE. BowTieHatr has a very good reputation on FTE. BowTieHatr has a very good reputation on FTE.
the 6.4 is still a 6.0, just bored and stroked a little here and there. the 6.4 is the 6.0 ford should have built, bigger better stronger.
__________________
To whom it may concern;
Ford Senior Master Tech since '05
ASE Master Tech '04
6.0ing since '03.
6.4ing IF they tear up
  #52 (permalink)
Old 04-24-2008, 02:43 PM
tex25025's Avatar
tex25025 tex25025 is online now
tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE.
Quote:
Technically speaking shouldn't it be what International should have built?
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
Suncoast Heavy Duty Torqshift Rebuild
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #53 (permalink)
Old 04-24-2008, 09:01 PM
scottman70's Avatar
Quote:
Yes, but Ford still chose to use there motors. So ultimately the responsibility lies with Ford and International combined. Hey when things are good (the 7.3 era) all was well. I really think Ford should have went after International for damaging there reputation and hurting sales of there diesel trucks. I have talked to a dozen guys who have switched to Dodge and GM diesels cuz of the 6.0. International should be paying up big time for all the 6.0 probs they have had to deal with!! I am sure there lawyers looked carefully over there contract with International! I am sure they would have used any loop-hole they could have for a breach of contract! Ford really marketed the new "twin turbo" Super Duty big time. Seems though with it's crappy mpg's,re-flashes, broken radiators, the early flamethrower issue etc...the 6.4 aint gonna be considered to be in a category with the 7.3 motor. Too bad!
Sorry for the rant, whoa this got looonnngg.
  #54 (permalink)
Old 04-24-2008, 09:16 PM
origcharger origcharger is online now
origcharger is gaining momentum as a positive member of FTE. origcharger is gaining momentum as a positive member of FTE.
International thinks they should go after Ford for damaging their reputation.
What came first? The chicken or the egg?
__________________
2004 E-450 6.0 137,500 miles
7,500 mile, 15 quart oil changes, 5W-40 Rotella.
UOAs consist of checking for metal on drain plug magnet. All stock, no mods. Dyed fuel with no additives. Never been reflashed.
Total parts replaced;
one EGR valve.
  #55 (permalink)
Old 04-25-2008, 02:41 AM
rollerstud98 rollerstud98 is offline
rollerstud98 is starting off with a positive reputation.
You need to stop living in the past, personally I believe the 6.4 will come out miles ahead of what the 7.3 ever was. I know my own 6.0 sure is
  #56 (permalink)
Old 04-25-2008, 01:52 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
There was what? Two reported cases of fire coming out the tailpipe? Broken radiators are not even related to the 6.4! International doesn't give ford radiators, ford buys them from another supplier, and what reflashes do you speak of? The 7.3 wasn't spotless either, HPOP failing, Oil draining out of HPOP reservoir, fuel delivery problems to the injectors, EBPV sticking/failing, "ROMP" problem, and a few 7.3s seem to enjoy putting holes in pistons.
  #57 (permalink)
Old 04-25-2008, 02:02 PM
rbaker6336's Avatar
Redneck Has Been
The 7.3 was and is a good motor but not a great motor,I have nrver been a fan of V-style diesel engines,but it's what came in the kind of truck I drive
__________________
Ray
PAA #35
  #58 (permalink)
Old 04-25-2008, 04:55 PM
The 6.4 is not a 6.0. They might share a block (which was about the only thing the 6.0 had that didn't break), but that's about it.
The 6.4 is everything that the 6.0 should have been. Common rail injection, pilot injection, servo actuated turbos VGT turbo, the heads stay on, very little turbo lag.
IMO the 6.4 will end up being better than the 7.3.
Mike
__________________
  #59 (permalink)
Old 04-26-2008, 02:18 AM
parkland's Avatar
parkland parkland is offline
parkland is gaining momentum as a positive member of FTE. parkland is gaining momentum as a positive member of FTE.
The 6.0 isnt ford, or international's motor. Its a international vt365, souped up by ford. Fact is, internationals version has more low end tourque, less problems, all around better.
Ford needs the engine to run like a gasser, and the ford parts and programming is what causes the problematic behavior.
__________________
2002 7.3 PSD 4x4 Nothing out of the ordinary.
  #60 (permalink)
Old 04-26-2008, 09:55 AM
Can't the 6.0s be wound upto to 4k+ RPM stock?
Tags
30e , power , stroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
