workbench stain and clearcoat
Put together my Kobal workbench last night and put two coats of minwax natural stain on it...sucked it in like you can't imagine and i'm sure it would suck in a few more coats.
I know the stain really won't protect it, so i'm going to clear coat it. any suggestions or will standard clearcoat (brushed) cut it? I don't want one so thick or glossy (like a bar's coating) that you can crack the coating and it starts chipping.
I'd prefer the suggestions be for easily obtained (ie: Walmart of Lowe's).
TIA.
Rob
TIA.
Rob
I would use a polyurethane varnish. You can take it to whatever level of finish you want by applying more coats, sanding in between. When you're done, give it plenty of time to cure and harden before using it. I like to throw a piece of Masonite on my bench when I'm going to do heavy or dirty work.
OK now you guy's are talking somthing I know about! The best finish is going to be a Marine Grade Polyurethane, If you seal with sanding sealer first you could get away with 2 coats of finish, if not you will need 3 or more coats to get the best results.
Do not thin the Poly with any mineral sprits, do not shake the can, Stir the material to get all the stuff that settles down to the bottom of the can, and use a good brush to apply the clear coats, The only thing i would worry about is the carb cleaner damaging the finish? Maybe a peice of tin would work better, just a thought.
I just per her together and haven't abused her yet.
haven't even bolted my 5" vice with anvil or my 6" bench grinder with gooseneck light on......starting out small....
have to take the coarse stone off the grinder and throw a wire wheel on it....I'll never use the coarse stone, and she has a medium on the other side.
If you want to keep it pretty then don't use it. 2nd the motion of putting masonite on top. An oil finish like tung oil can be used and easy to repair, oil- based poly would be more durable. A friend who owned a local bar covered the top of the bar with a 2 part epoxy finish that was very durable (until the place burned down)
Cabot Stains Oil Polyurethane | Cabot
instead of what i bought tonight, this
Cabot Stains Spar Varnish Product | Cabot
More durable as to wet and sunlight. However, as to objects being placed on it or (more to the point) hammered on it, not really. I am new to finishes but have been doing a lot of research on it lately as I have been refinishing my floors and I am going to redo the woodwork in my 90 plus year old home. From what I have gathered all finishes (other than oil finishes like Tung oil) can crack from being hit. I agree with the others that the only way to keep it looking good is to put something on top when working.
