94 Ranger 2.3L SOHC Trouble Code Help - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 04-12-2008, 09:29 PM
cmccul002 cmccul002 is offline
cmccul002 is starting off with a positive reputation.
Well, the truck is still running, but I have some trouble codes.
I didn't want to start a new thread, even though the truck is now running.
I got some continuous memory code:
172- Heated Exhaust Gas Oxygen (HEGO) sensor- voltage signal indicates "Lean" (Bank #1)
181 - Heated Exhaust Gas Oxygen (HEGO) sensor- voltage signal not switching: indicates "lean" during part throttle engine operation (Bank #1).
332- Insufficient EGR flow detected.
542 - fuel pump circuit open connection - Electronic Control Assembly (ECA) to motor ground,
Then KOER test -
172 - Heated Exhaust Gas Oxygen (HEGO) sensor- voltage signal indicates "Lean" (Bank #1)
332 - Insufficient EGR flow detected.
538 - Insufficient RPM chang during Dynamic Response test (Engine Self Run Test)
Old 04-12-2008, 10:32 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
I would address the EGR codes first. DTC 332 can be caused by a bad DPFE sensor, or else something like clogged EGR nostrils or blocked hoses.
Old 04-13-2008, 07:59 AM
pawpaw pawpaw is online now
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Quote:
I agree with Rockledge, begin with checking the EGR systems DPFE sensor, as it's a common failure part & seeing as how you also have a lean O2 sensor code, to go along with the EGR system operational trouble codes, you may have more than one EGR system problem, so I might also consider taking a real close look at the EGR's vacuum control system network, for leaks.
So on your trouble shoot, maybe consider backing up all the way to the EGR's VSV (Vacuum Switching Valve), to check it's diaphragm for leaks, then it's vacuum lnes all the way to the EGR valve & the EGR's diaphragm for leaks, along with the DPFE sensor & it's vacuum lines.
The code 538 suggests you didn't punch the gas pedal far enough on the "throttle up" portion of the KOER test, that checks the TPS sensor, so I wouldn't worry about it just now.
Just some more thoughts for consideration.
Let us know what you find.
OBD 1 Codes 172 and 538 danielwd Ranger & B-Series 9 09-16-2016 01:04 AM
5.4L Trouble Codes Duckman77 Expedition & Navigator 2 05-13-2013 09:37 PM
Troubleshooting Egr Codes BCHauler 1987 - 1996 F150 & Larger F-Series Trucks 11 10-02-2008 05:27 PM
Help Me Break The Codes WARedBear Aerostar 25 10-08-2007 03:53 PM
93 Explorer Code 172 cb4492 Explorer, Sport Trac, Mountaineer & Aviator 10 07-28-2004 01:19 PM
Tags
172, 23, 332, code, dtc, ford, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
