I got a fairly straight '59 F series I drug home from an auction ($CHEAP$ ), I got it running , Im told its a 223 cid; any info on this engine, I know little about them, seems to be low geared !
223c.i. I-6, "Mileage Maker Six": 1954-1965, Industial applications '67: bore 3.625 X stroke 3.6
Chain driven cam, distributor in front right, '54-'60 used 7/16" Head Bolts, '61-'67 used 1/2" head bolts, '54-'59 2 nuts holding down valve cover, '60-'67 8 bolts holding down valve cover, '63-'64 Police Interceptor & Special Taxicab engines used a gear driven cam.
Found in light trucks & cars, tractors & industrial applications, Found in Ford model 6000 gas tractors: Found in DIVCO trucks as the "F" series motor to '65(?)
'55 block & intake painted yellow, valve cover silver: '57-'58 block & intake painted red, valve cover black: '59-'60 block & intake painted black, valve cover red: '63-'67 painted same as 170 Special c.i. I-6
Door codes; cars- '54-'59: A, '60-'64: V, trucks- -'64: J
__________________
Cheers
Colonel Flashman
Vermilion '58 Mercury M-100 HP 312 I-6 w/ HP C-4
Blue '58 Mercury M-100 Panel 223 I-6 w/ M-O-M
Black 1893 Henry Ford Quadra-Cycle (replica) My Replies Are Not Meant In An Offensive Way.... Ever, They Are Merely.... Straight Answers or Comments
Four main bearing engine, Holley visa bowl single barrel carb, valve clearence I believe was .019, late model had a mechanial zero lash a rocker arm set up. Overall a very reliable engine, only problem I know of was a problem with timing chains wearing and getting noisey. I owned two one in a 59 f100 which I bought cheap because they thought it had a burnt valve, but it was adjusted to tight and one in a 56 sedan. Never had a bit of problem with either. Drove the truck 14 years and the car 8. kotzy
with high mileage and wear on the rear main, there were many that broke the crank, usually at an angle on the rear main journal
that was the only common problem I know of............I had one do that in a '59 P/U
just put a crank kit in while engine still in the truck
be very careful with the 7/16 head bolts, when re-using, at least one will break just before the spec. torque
not very good oiling to the rocker arm shaft, usually had to be replaced on a rebuild
I had the truck for about 10 years, sold it about 20 years ago, and still see it running
(I guess the rebuild I did worked ok)
btw, always had trouble with the Holley 1 bbl, made an adapter and ran a small 2 bbl Rochester of and old 283 chevy............ran great
The ONLY reason for Oiling Blockage was Because the Owners were NOT maintaining the engine Properly w/ Regular Oil Changes.
As long as you Regularly Maintain the 223c.i. I-6, You will Not have a blockage problem.
__________________
Cheers
Colonel Flashman
