Go Back   Ford Truck Enthusiasts Forums > Misc. > Towing, Trailers And 5th Wheels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 04-12-2008, 04:01 PM
Dave977 Dave977 is offline
Dave977 is starting off with a positive reputation.
Testing trailer brakes
I am in the process of testing to see if my brakes on my trailer work. Being that I am doing this alone, if the drum is off and I pull the breakaway switch, shouldn't the brakes be locked open? I do have electricity to the brakes and by me pushing the brakes in the truck, I can't see or hear if anything is happening. Hopefully this all makes sense to you guys.
Also, from a safety/regulations standpoint, shouldn't there be brakes on both sides of the trailer. This trailer has brakes on all four wheels but only two wired up, both on the same side of the trailer.
Thanks!
  #2 (permalink)
Old 04-12-2008, 07:33 PM
gbadgley gbadgley is offline
gbadgley is starting off with a positive reputation.
check to see If the battery powering the break a way system has a charge, or the switch could be bad. If you have 4 wheel brakes the all need to be wired in, 2 on one side will get you in trouble FAST!! Greg
__________________
If I can't fix it, I can screw it up so bad no one else can either!
  #3 (permalink)
Old 04-12-2008, 07:43 PM
Toyman's Avatar
Toyman Toyman is offline
local rackoholic
Toyman has a good reputation on FTE. Toyman has a good reputation on FTE.
You won't see anything move, but you should hear a click sound of the magent. The magent actually attaches itself to the hub/drum, as it rotates it twists the arm and forces the shoes apart making contact with the surface of the drum. You should be able to check with a meter if you have power going to the magnets by pulling the emergency cable, provided that there is power in the battery. One thing to look at is the connections by the backing plates, usually they are "scotch lock" and don't keep a good connection. I replace mine on every new trailer I have bought with good heat shrink butt connectors.
Good luck.
Toyman
__________________
2005 F350 Crew Cab SB
2002 Explorer
2000 F650
member: FTE ORDER of Blue Max
  #4 (permalink)
Old 04-12-2008, 07:44 PM
99whiteford's Avatar
99whiteford 99whiteford is offline
99whiteford is starting off with a positive reputation.
If you have the drum off the barkes CANT work.on most electric brakes they use a magnet that ,,when powered is applied ,,tries to stick to drum.read on here somewhere the other day to use a compass..hold it next to wheel and when power is applied the compass will move.
__________________
06 F -350 Crew Cab
00 F-150
03 Harley Ultraglide
29 foot Jayco Quest F'ver
Its better to keep your mouth shut and let others think you're fool,than to open it and remove all doubt
  #5 (permalink)
Old 04-12-2008, 07:46 PM
Delawhere? Delawhere? is offline
Delawhere? is starting off with a positive reputation.
Thanks!
Hopefully you have found out by now that if you have four wheels they all have electric brakes and are hooked up. If they aren't you definetely have a problem. You can test the brakes for proper working order by checking the amp draw at each wheel. You will have to put an amp meter inline with one of the electric wires going into the brake. You can also test for voltage at the brake as well. Not sure where you are located but if you have a Camping World store close by I can say they have done a great job for me fixing some of my RV problems. Happy Camping!
__________________
05' Lariat, F250, Ext. Cab, LB, 6.0L Dsl, 37' Cedar Creek Fifth Wheel Trailer & Pullrite hitch. Pyro & trans guages plus a Mag-Hytec trans pan and MBRP cat back exhaust system.
  #6 (permalink)
Old 04-12-2008, 10:31 PM
firedewd's Avatar
firedewd firedewd is offline
firedewd is starting off with a positive reputation.
For the wiring to only one side, my brake wires comes back along the driver's side of the trailer to the axles, then split and run through the axle to the other side. So on the passenger side, there is very little visible wire.
__________________
They told me it's not rocket surgery!
2000 F250 CC SB PS
Wilderness 5th Wheel
Starcraft Tent Trailer
The sooner I fall behind,
the more time I have to catch up!
  #7 (permalink)
Old 04-12-2008, 10:51 PM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
1994 Ford Mustang
My Garage
MisterCMK has much to be proud of MisterCMK has much to be proud of MisterCMK has much to be proud of MisterCMK has much to be proud of MisterCMK has much to be proud of MisterCMK has much to be proud of MisterCMK has much to be proud of MisterCMK has much to be proud of
Lift each side of the trailer when you are testing the breakaway. Pull the cable to engage it (with the tow vehicle disconnected)and try turning a wheel. It should turn a little bit and then engage the brake as it comes around. If the brakes engage, great. If not you will have to start troubleshooting. Check the battery in the breakaway as they can be neglected.
__________________
Chris
Is winter over yet?
  #8 (permalink)
Old 04-13-2008, 06:24 AM
Thank you for the responses. It is nice to know that there are helpful people out there with great info. Thanks again!
  #9 (permalink)
Old 04-13-2008, 02:42 PM
wb6vvv's Avatar
wb6vvv wb6vvv is offline
wb6vvv is starting off with a positive reputation.
Just be sure and rotate the wheel in the forward direction. The electric brakes don't hold in the reverse direction.
__________________
Gary
1977 F250 460 Hauler, 1986 T-Bird 3.8 V6
  #10 (permalink)
Old 04-14-2008, 09:14 PM
BareBones BareBones is offline
BareBones is gaining momentum as a positive member of FTE.
Ditto on the one-side-only wiring observation. Mine wire to one side, then run through the axle to the other side.
__________________
2005 F350 V10 6spd dually, 15K receiver. No 4WD, no LS, no A/C, no special cab - just a lean mean towing machine!
Tags
amperage , brake , brakes , clicking , electric , f350 , hear , hooked , magnet , noise , test , tester , testing , trailer , truck , working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
