Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-12-2008, 03:23 PM
kssouth is starting off with a positive reputation.
true duel conversion for 300?
i am currently building a 65 f250 . i have installed a 1986 300 i6 into the truck to replace the blown 240.i recently aquired a set of true duel exaust manifolds for the 300.my question is how do you convert the original intake over to the true duels .the single exhaust manifold and intake bolt together and if i remove the exhaust that will leave a opening in the bottom of the intake won't it? someone told me it was possible to just weld a plate over the hole in the bottom of the intake and this would cure the problem but i am not sure. and is their any problems with the true duel exhaust i should watch out for,because i have read pro's and cons for the true duel set up .some people say you can't use true duels on a carburated engine and others say their is no problem..............................any advice would be appriciated
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-12-2008, 08:49 PM
Duke78's Avatar
Duke78 is starting off with a positive reputation.
Search the forums, this is a beat to death topic. The only thing to watch out for that i know of is the alt bracket. You may have to cut a bit of it out to get headers on there, if you're using the EFI exhaust the you should be fine.
__________________
1978 F-150 Ranger
300 I-6, no emission
4 speed, 4x4
  #3 (permalink)
Old 04-13-2008, 03:35 PM
Harte3 is starting off with a positive reputation.
That is just an indentation in the bottom of the intake...it doesn't go any where. But, if you are going to need manifold heat you can fabricate a plate plumbed with hose barbs and bolt it to the manifold and run water heat through it from a heater hose. The stock arrangement provided this by means of exhaust heat.
There are a few valid pros and cons...but mostly just differences in opinion. It is a fact that a carbureted engine can be dualed out.
__________________
1983 F150 300 I6, Comp Cam 260h and lifter kit, Port/Polished head, Offy DP Manifold, Holley 4360 Economizer 450 cfm, EFI Exhaust manifolds, Walker Y Pipe to 3-Way Cat, generic Turbo Muffler, Recurved DSII, Mallory HyFire 6a & ACCEL Super Stock Coil, Taylor Spiro Pro Wires, EFI plugs.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
