Plug wire diagram - Ford Truck Enthusiasts Forums
Plug wire diagram
Old 04-12-2008, 01:12 PM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
Plug wire diagram
Well I got new Ford Racing 9mm plug wires and new MSD cap and rotor today put them on and it starts but the whole truck shakes and when I hit the gas it barley revs up. Im thinking the plug wires are on wrong.
Anyone have a plug wire diagram for my truck?
Also when I put the new MSD cap on it didn't line up like the old one. The little black plug on the new cap are in different spots.
In the picture I have both caps lined up and you can see the black plug is in different spots.
Here is the diagram I used
Here is how I have it wired
Isnt the firing order 1-5-4-2-6-3-7-8??
Old 04-12-2008, 01:28 PM
86F150302's Avatar
put in the 1-5-4-2-6-3-7-8 firing order and it runs great
Old 04-12-2008, 01:58 PM
woodn1 woodn1 is offline
woodn1 is starting off with a positive reputation.
I noticed in your pics, the text Has the firing order 1-3-7-2-6-5-4-8 ( for a '94 & up 5.0)
I have a 90 5.0 that I have put a carb on and vacuum advance disrtibutor. I wired mine
1-5-4-2-6-3-7-8, However , I just installed this motor and don't have it fired up yet.
I can't say for sure , cause I can't see which plug, the wires lead to, but it looks wrong to me.
Old 04-12-2008, 02:30 PM
86F150302's Avatar
yep the way I had it was for 94+ I ended up doing it 1-5-4-2-6-3-7-8 and its running good now.
Old 04-12-2008, 09:23 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
1-3-7-2-6-5-4-8 is the 351w firing order. High output 302's in mustangs also used this firing order. Are these instructions for 90-up trucks? I don't know if they changed to the 351w firing order or not.
When you put in aftermarket cams, you have to watch out for this. The cam could have either firing order, so you might have to switch the wires around sometimes.
1-5-4-2-6-3-7-8 is the old 302 firing order, and was also the firing order for "normal" non-HO engines in the later models. If you notice, #7 and #8 are right next to each other in the order, and also right next to each other physically on the engine(driver's side rear). They have problems with the spark jumping between these two wires, especially when you make them pretty and line them up side by side all the way to the cylinder head. The best thing to do is run them totally opposite in the sparkplug looms.
Old 04-13-2008, 08:00 AM
86F150302's Avatar
Yep I didn't know they changed the firing order on the 302s either.
Runs great
Projector headlight retrofit 86F150302 1987 - 1996 F150 & Larger F-Series Trucks 26 12-30-2016 08:25 PM
E350 Backup Camera install Killer RC 1968-2013 Full Size Vans 29 03-26-2013 09:26 AM
Genex Auto Dim/Temp/Compass Install Directions Bigfwt04 1999 - 2003 7.3L Power Stroke Diesel 38 12-22-2008 12:47 PM
stock 1999 Expedition 4X4 with Wrangler MT/R 305/70-17 tires lllateralus 1997-2006 Expedition & Navigator 11 10-19-2007 06:54 PM
Look at this family of fine Fords !!!! bigun72 General Automotive Discussion 17 08-17-2007 04:30 PM
Tags
1977, 302, 351, bov, diagram, diogram, f150, firing, ford, location, order, plug, spark, supercharged, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
