Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-12-2008, 12:14 AM
83maverickf-100 is starting off with a positive reputation.
what is pluged
i have come to realise that this is not normall the vacume line on top of the air breather on a 83-f100 make the engine run better when it is disconected! the engine speeds up gust a bit but smoothens out and gets way more power and sounds totally diffrent i put it back on i know i shouldnt run it wothout/ but why does it run better with it off? there is loots of vacume going trough it truck always runs good gas millage suck though
sorry for long qeustion
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-12-2008, 10:21 AM
fmc400's Avatar
fmc400 has a good reputation on FTE.fmc400 has a good reputation on FTE.
Normally, on a healthy engine, combustion fumes escape past the piston rings and enter the combustion chamber. They are then directed back into the intake manifold through the PCV valve. A breather filter on the other end accepts fresh air into the crank case, through the breather hose.
If you're talking about the breather hose, then your situation is due to excessive blow by. On old engines, there is so much blow-by that the PCV system is in effect swamped by blow-by, and the crankcase fills with more fumes than the system can suck out. So it tries to escape any way it can - even out the breather hose. This is bad because the breather hose is supposed to take in fresh air, not dump combustion fumes out. What happens next, is the breather filter starts fouling, and eventually the air filter starts fowling. Another term is "throwing oil." The engine begins to bog down due to excessive crankcase pressure.
So, sometimes people will disconnect this hose to let the fumes escape, and it will run better because this helps release crankcase pressure and the engine bogs down less. Normally, you're not supposed to disconnect this hose because it needs a filter on it. But, if your engine's blow-by is so bad that it just keeps dumping fumes and fowling breathers, then your PCV isn't really helping anymore and it really doesn't matter if you leave it connected or not. My '77 LTD has a 351W and is this way. The blowby is so bad that it comes out the breather hose and the PCV hose at the same time. I just ran a 5/8" heater hose from the valve cover grommet down to the ground to dump the fumes.
This is all assuming you are talking about the breather hose, because this is the only case that would make sense. If you're talking about an actual vacuum hose, then it's not supposed to run better with it disconnected. Vacuum leaks are bad. If a vacuum leak makes your engine run better, you have a problem. My guess would be your idle is too rich, which would also contribute to the poor gas mileage you mentioned. You need to clarify which hose you are talking about.
Hope that helps, sorry but a long question needs a long answer.
  #3 (permalink)
Old 04-12-2008, 10:01 PM
the case around the air filter (the air breather is what i call it) has two line on the top of it with two spots to plug them into if you take the one that sucks air off the engine it idles up but has a better top end the blow by isnt bad the hose at the front of the valve cover on the oil cap has be ran to the growned because of it but it took about a month and 2week for oil two show up in the air breather case thats why its disconected
  #4 (permalink)
Old 04-12-2008, 11:16 PM
ford2go's Avatar
ford2go is gaining momentum as a positive member of FTE.ford2go is gaining momentum as a positive member of FTE.
If I'm reading this right you're disconnecting 2 lines one goes to the underside of your air filter case. This is the one that helps your power. The other one is to your PCV. You disconnected the 2nd one because it squirts oil into your air filter.
I don't think these are related. Your PVC problem is probably what fmc400 said. As for the 2nd -- this is strange.
What you're describing should be the hose that causes the snorkel to switch to cold air after the engine warms up. Before that it's supposed to suck air from the hose going down by the exhaust.
I can see that you could have some kind of a restriction in your fresh air intake. In that case, you would be better if it kept sucking through the hose going down by the exhaust . If the hose to the exhaust is rotted away, then
it would work even better.
What I can't see is how you can get by with causing a vacuum leak. What happens if you pull the hose off of the air cleaner and plug the end? If it runs even better then you have a restriction in your cold air intake. If it runs worse, then you have one screwy problem.
good luck,
ford2go
  #5 (permalink)
Old 04-13-2008, 01:01 AM
fmc400's Avatar
Okay, I understand what you're saying now. You already have the breather hose running to the ground because of blow-by (I had to do that on a car too, like I said). You're actually disconnecting a vacuum line. Your idle is going up because of a vacuum leak. Like ford2go said, that's odd. My guess is you're running too rich and the vacuum leak is leaning it out to spec.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
