Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-11-2008, 11:27 PM
floydguy is starting off with a positive reputation.
truck is now running excellent
my 1987 ranger 2.9 super cab 5 speed.............i finally got it right, first my bad clutch and slave, the replaced the cracked heads with 1989 bronco 2* 2.9 heads, tackled the broken exhaust* manifold bolts, cleaned valves, new valve seals, cleaned and repainted heads and intake/ fuel rail, adjusted valve lash properly, new injector, o rings, ive cleaned the throttle body iac, valve, egr valve, new theremostat, ran it, let it cool, and i retorqued the intake and valve covers, set the timming. it runs great, no smoke, no water in the oil, doesnt overheat, and no blow by, it idles smooth and starts everytime, im impressed. the extra work paid off. thanks for all the imput everyone.
i just cant stand those tapping injectors!!!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-12-2008, 09:48 AM
TigerDan's Avatar
TigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud of
Sounds good, glad you got it all together!
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
  #3 (permalink)
Old 04-16-2008, 10:27 PM
one small issue.......
its running fine, but sometimes it will clatter on start up, but the oil pressure is normal, when warm it lowers some right in the middle of the "M" at idle, at highway speeds it will be just below the "R" while warm, it will get a little lower, when idled longer, but never gos dangerously low, the guage does seems kinda slow, should i get another sending unit? will i be okay or is this gonna be trouble in the future?
  #4 (permalink)
Old 04-16-2008, 11:12 PM
TigerDan's Avatar
The factory oil pressure gauges on these trucks aren't accurate. They're actually a sort of idiot light with a needle, they show pressure in the normal range as long as it's above something like 7 psi. Some folks report fluctuations in gauge readings which leads them to believe that the gauge is actually showing true pressure. I guess Ford had too many folks panic when the oil pressure would fluctuate, it's actually fairly normal for the pressure to be somewhat low at idle and low RPM. If you want a true representation of your oil pressure you should install a mechanical gauge.
__________________
FTE Moderator
  #5 (permalink)
Old 04-17-2008, 09:09 PM
yeah i was considering installing a sunpro oil pressure guage i had laying around i just need a new tube kit for it though.
i was just slightly concerned maybe the the crank bearings suffered some damage during the water/oil issue, i dont know how long/hard the previous owner drove it with the cracked head, i do hear a slight clatter at higher rpms before 2nd and 3rd shifts sometimes and on some start ups, but the factory guage never gets dangerously low. im gonna try the manual guage, atleast it has numbers. the oil pan is slightly leaking, i will eventually fix that along with a fresh oil pump. i have been driving it right regular now, has plenty of power.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
