Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Iowa Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Iowa Chapter Join Chapter, Leader: fellro86
  #1 (permalink)
Old 04-11-2008, 11:40 AM
FARM69's Avatar
FARM69 FARM69 is offline
Garage is empty, add now
FARM69 is gaining momentum as a positive member of FTE.
Semi-Truck parts
Does anybody know if there is a used parts off for semi-trucks? I'm looking for a good used holset turbo of a M11 or L10 cummins. Thanks for the help guys.
__________________
97' F250HD 4x4 Intercooled Powerstroke 5 Speed LB / Stage II (180cc) Injectors / HX50 Turbo (19cm) / DP-TUNER / Electric Fuel / Val Air Ceramic
A-Pillar AutoMeter Cobalts [Boost, Pyro, Water/Oil Temp]
4" Straight / 6637 / CCV / 203 Stat
  #2 (permalink)
Old 04-11-2008, 10:56 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
Vander Haag's parts them in your area, there are others around as well. Trump Trucks in Kahoka, Mo does a lot of them as well.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #3 (permalink)
Old 04-12-2008, 09:59 AM
FARM69's Avatar
Thanks fellro, I'll give Vander Haag's a call.
__________________
  #4 (permalink)
Old 04-27-2008, 09:01 AM
farmdad's Avatar
farmdad farmdad is offline
farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.
I know that this is a little late but try B&D truck parts in Blair, NE. (800) 343-2873 They have quite an extensive parts yard. Good to deal with.
__________________
Mark
'03 F350 PSD, 4x4, SC, LB, Super Chip, B&W, AIS, Zoodad, Rough Country (so far)
If it has wheels and an engine, you have my attention.
  #5 (permalink)
Old 11-10-2008, 10:34 PM
the_hetz's Avatar
the_hetz the_hetz is offline
the_hetz is starting off with a positive reputation.
Vander Haag's...my one true foe...
__________________
89' F150, 302, 4x4, AOD, 143k (RIP)
74' F250, 390, 2wd, C6, 51k
  #6 (permalink)
Old 11-19-2008, 08:41 PM
FARM69's Avatar
Thanks for the reply guys. I ended finding a brand new turbo (new for a 10.8L M11!) on Ebay for an amazing price. I've only had the engine idling because I'm still working on the discharge pipe along with intercooler pipes, but the project is coming together nicely. Just wish we could finish harvest...
__________________
Tags
2008, engine, ford, fordsemitruckparts, parts, semi, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
