Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-10-2008, 10:13 PM
DouglasU is starting off with a positive reputation.
Idle problems and stumbling/backfiring at speed
I don't know if these are related but I have an 88 150 witha 4.9l/5-speed. The engine idles at 1200-1500rpm and also has a miss at idle. When running at highway speed it will often (but not always) start to miss, backfire, and stumble which usually will go away if you floor it, it often comes back
minutes later. This truck was acting like this until one day it wouldn't run at all which is when I bought it and traced out and replaced a faulty crankshaft position sensor which I think is unrelated. The computer will not give me any code but the 10 code. The ignition module tests good, the coil resistence test is good, the fuel pressure at the fuel rail is good at idle, it has new plugs, cap/rotor, and filters. The timing is set correctly. If anyone can point me in the right direction or has had a similar problem I would appreciate your input.
Sponsored Links
To remove this ad, register today!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
