squeaking in motor
[quote=WALJON;6026135]
Maybe that was the wrong way to state that. It should spin freely by hand with no binding/grinding. There should be a little resistance. If it's bad you'll know it.
The best way to find the noise is with a mechanics stethoscope or something similar while it's running (chunk of wood, screwdriver ect).
Check your air lines off the vacuum pump and even down to the little lines that go to your heating duct doors. Repair as necessary. The vacuum pump generates a pretty good vacuum and sucks dust and sand into itself which will kill it within a year if dirt is getting in there. A vacuum pump will last indefinitely with no dirt intrusion.
matt0963
1983 - 2012 Ranger & B-Series
04-09-2018 12:59 PM
4WheelDriveVan
1997 - 2003 F150
12-10-2010 07:30 AM
racine
10-06-2010 10:31 PM
