2007 Ex Trouble Codes P0671,3,5,7
Old 04-10-2008, 09:17 PM
parkerexcursion's Avatar
parkerexcursion
parkerexcursion is offline
I have a 2001 Ford Excursion, got the SES light about a month ago, I had a local diesel guy look at it and he replaced the GPCM, light was off for about 2 days them came back on. I've looked it over an don't see any loose wires. The local shop can't tell me what it is exactly, but they are more than willing to research it for $90/hour. While checking the wiring i looked at the GPCM, it looks pretty dirty for being new so I'm starting to wonder if he just reset the OBD? Either way, does anyone have any thoughts as to what would be causing the 4 error codes P0671, P0673, P0675, AND P0677?
Thanks.
Old 04-10-2008, 09:38 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
Welcome to FTE
I would also be suspicion of a dirty looking NEW GPCM. The codes point to all four glow plugs in cylinders 1, 3, 5, 7 as bad, which I doubt. Maybe he found one of the connectors loose and just re-seated it and it has come loose again. Here is a diagram of the GPCM and wiring/connectors. May even be a bad GPCM if it was not really replaced or replaced with one removed from another vehicle. You should go talk to this guy.
Rmblanchard2
09-23-2013 05:59 PM
skyskibum
07-25-2013 01:18 PM
npccpartsman
07-17-2013 10:48 AM
Gruntface
04-30-2012 05:37 PM
eggturner
16
12-01-2010 04:41 PM
Quick Reply: 2007 Ex Trouble Codes P0671,3,5,7
