Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 04-10-2008, 07:45 PM
motoman97 motoman97 is offline
Garage is empty, add now
motoman97 is starting off with a positive reputation.
How many running b100 in 6.0
How many of you guys are running the 6.0 on B100. If so any problems.
Thanks
  #2 (permalink)
Old 04-10-2008, 09:26 PM
Simmy69's Avatar
Simmy69 Simmy69 is offline
Simmy69 is starting off with a positive reputation.
I run B100 about every other tank. No problems and it's about .20 cents cheaper than #2 here in Hawaii.
__________________
2007 F250 LARIAT 6.0 SUPERCAB 4X4 FX4, EGR Delete, 4" Turbo Back, SCT xCal III
  #3 (permalink)
Old 04-10-2008, 09:45 PM
I am going to make mine at a cost of .73 gallon. Can you tell the difference
  #4 (permalink)
Old 04-11-2008, 01:09 AM
adambomb's Avatar
adambomb adambomb is offline
2005 Ford F-350
adambomb has a good reputation on FTE.adambomb has a good reputation on FTE.
i run biodiesel when ever i can. not very much lately because i lost my source and the nearest station isn't that near. i think my truck runs great on bio, super smooth and can't feel any loss in power. i did loose my injectors after the 2 or 3 tank of b100 i ran though. my fuel filters got plugged which caused the injectors to starve for fuel. it all happend so quick to be honest i didn't even have any warning. i still run bio and got a FASS Fuel System for extra protection now.
__________________
2011 Escape Limited v6 (Loaded) ESP 7yr/65k and Full Ford Maintenance Plan
2005 F350 6.0 (modded) ~450rwhp/900+ft/lb tq
1999 F350 7.3 (normal mods + 13" King Suspension on 40's)
1998 F150 (basic mods + 7" Suspension on 35's/Prerunner fiberglass and skidplace)
1994 Bronco (normal mods + 9" Coil Suspension on 35's)
  #5 (permalink)
Old 04-11-2008, 04:11 PM
Simmy69's Avatar
My engine runs quieter. I do have to drain the water separator more often. I try to do it every month. I change my fuel filters every 10,000 miles.
__________________
  #6 (permalink)
Old 04-11-2008, 08:21 PM
Is that on b100
  #7 (permalink)
Old 04-13-2008, 10:28 PM
bradyracing bradyracing is offline
bradyracing is starting off with a positive reputation.
I run B100 in a 2004 F250 if the low temp is going to be above 30 degrees and B50 if below 30 degrees. Bought truck with 106K on it and was running B20 in it thirty minutes after I signed the papers. Went to B100 at 130K and have 154K on it now. No water separator problems, no filter problems. Gelled up one time with B100 at 28 degrees. Had truck refired three hours later at 34 degrees with two electric heaters aimed at center of fuel tank. Never even changed the filters that day (didn't have any with me).
__________________
2004.25 F250 CC Powerstroke on B100, 220K miles
1992 F350 CC SRW 4x4 Cummins powered, on B100
Biodiesel maker
http://community.webshots.com/user/b...host=community
  #8 (permalink)
Old 04-14-2008, 02:09 AM
Simmy69's Avatar
On B100 it runs better. I do live in Hawaii, so I don't have to worry about low temps.
__________________
  #9 (permalink)
Old 04-14-2008, 05:27 PM
hd4ever hd4ever is offline
hd4ever is starting off with a positive reputation.
Hi
The big question is how many miles have you guys run on 100b and how many miles on truck?
Thanks
  #10 (permalink)
Old 04-14-2008, 07:26 PM
Simmy69's Avatar
About 1/3 of my 17,500 miles are on B100, but always a mix, 1 tank of #2 then 1 or 2 tanks of B100 or maybe the other way around. There is only 1 gas station on Oahu that sells B100, that I know of. So I fill up where ever I need to.
__________________
  #11 (permalink)
Old 04-18-2008, 02:56 PM
adambomb's Avatar
2005 Ford F-350
i can't believe that there are this few people running biodiesel in a 6.0l on this forum. what do you guys think is the reason? availability? warranty? uneducated?
__________________
  #12 (permalink)
Old 04-18-2008, 04:45 PM
Herkmafia Herkmafia is offline
Herkmafia is starting off with a positive reputation.
Quote:
Quote:
Thanks
The question was B100. I was running b5 in little rock, AR but haven't found any biodiesel in Abilene, TX yet. Personally I've never seen B100 for sale and don't have a big enough place to make enough to run it straight.
  #13 (permalink)
Old 04-18-2008, 05:20 PM
tazo's Avatar
tazo tazo is offline
tazo is gaining momentum as a positive member of FTE.
Filled up with B100 on Monday. I have been running B50 to B80 for the last few months. The reason I have not been running B100 is the temps get down low 30s to upper 20s. I didnt want to worry about gelling. I do notice a different tone in the motor. It runs really quiet and smooth. It's my view that most do not know about biodiesel and are afraid to use it. There was talk at my daughters school that bio fuels are bad because of what it is. And it's taking away food from us and destroying our land.. I quickly set them straight and gave the short version lecture.
__________________
2005 F350 6.0 lariat supercab 4x4 long bed zf6 speed and a real work horse--Burning B100 on nice days and B50 when there is a chill in the air
Mod's-BD exhaust brake-Dura flaps-Piaa back up lights-C-Betr mirrors
-Midwest short throw shifter-Splitz lift-Wilson cell antenna & Amp--Isspro ev gauges-fuel-pyro-ebp
1999 EB expedition (Wife's)
  #14 (permalink)
Old 04-18-2008, 08:27 PM
slowmans's Avatar
slowmans slowmans is offline
slowmans is gaining momentum as a positive member of FTE.slowmans is gaining momentum as a positive member of FTE.
I have been running b-5( mixing in b100 when I get fuel) since december, but I think im gonna start to run b-20 since its getting warmer here in mass.- I would love to run b-50 or so but I pay 4.99 a gal for the b-100 so its a bit too steep to run stronger?
  #15 (permalink)
Old 04-18-2008, 08:30 PM
Frankenbiker's Avatar
Frankenbiker Frankenbiker is online now
Frankenbiker has a great reputation on FTE.Frankenbiker has a great reputation on FTE.Frankenbiker has a great reputation on FTE.Frankenbiker has a great reputation on FTE.Frankenbiker has a great reputation on FTE.Frankenbiker has a great reputation on FTE.
frankenbiker
A significant percentage is availability, with the rest going to warranty.
Retailers with QUALITY biofuel are pretty few and far between. In the Dallas/Fort Worth area, the biofuel retailers are in either downtown Dallas, or downtown Fort Worth; it's a 60-mile round trip to get biofuel for me (of ANY kind, much less quality) when non-biofuel is 4 blocks away -- and one of the cheaper stations in the area, to boot. (As a matter of record, if I were in Austin, I'd buy it a lot more; there, you're never more than 5 miles from a bio-retailer, usually B20.)
Running anything but QUALITY fuel in a 6.0 hits a little too close to home on an already skittish warranty policy from Ford. Ford endorses no more than B5, and that concentration is too low for it to be worth the effort for most retailers.
As the 6.0 platform ages a little more (i.e. running out of warranty), you'll see more people using it.
Part of the problem, too, is that there are still too many people who equate "biodiesel" to running old french-fry oil. This is what kills it for a lot of folks, Ford Corporate included. There *IS* a difference between WVO and commercially-prepared, properly blended, and taxed, biodiesel, and THAT's a perception problem that'll take a LONG time to fix.
-blaine
Tags
100, 2011, 60, 67, b100, biodiesel, biofuel, f250, ford, frod, liter, powerstroke, problems, run, running, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
