Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-10-2008, 06:03 PM
Customcab's Avatar
Customcab Customcab is offline
Customcab is gaining momentum as a positive member of FTE.
352 Oil filter mount.
I realize a truck oil mount is horizontial and passenger car's are vertical. But why can't I use a vertical oil filter mount instead of a truck type. I beleive there's enough clearance over the top of the crossmember or is there????
Future plans on installing a 352 4V from a 65 Galaxie 500 into my 65 F100.
Pending my financial planning. lol
Mitch
__________________
Customcab 65 F100 SWB w/ 302cid & C6.
64 F100 SWB 223/3spd;
76 F100 LWB 300/C4
78 F100 LWB 302/C6 "Kids 1st Truck"
99 Pontiac GTP "Wife's other Ride"
03 Mountainer "Family Wagon"
  #2 (permalink)
Old 04-10-2008, 10:53 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a good reputation on FTE. garbz2 has a good reputation on FTE.
No reason it don't work, There is enough room. But it just allows more oil to drool on the cross member as it will dump a quart as you spin it off..
Garbz
__________________
64 F100 "Christine" 472 EFI C6 and mean
63 F100 Uni Custom under construction 4" off the pavement and built to drive 410, C6.
69 F250 Crew Hiboy 360 435. Driver.
05 Escape XLT
  #3 (permalink)
Old 04-11-2008, 01:24 PM
Customcab's Avatar
I figure it would work; due to a buddy having a 428 inside a 72 2wd, using the same engine perches, I seen good clearance and I guess folks just think it has to be a truck motor look( horizontial filter); instead of a well built machine. I like the vertical filter; seems less messy in changing my oil, when the filter screw downward insted of side ways.
Thanks for the reply Garbz.
Mitch
__________________
76 F100 LWB 300/C4
  #4 (permalink)
Old 04-11-2008, 09:15 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Mitch
Simple solution if you have a clearance problem, or want to use a shorter oil filter.
Use an FL-300 oil filter instead of a FL-1-A.
Ford came out with the FL-300 in 1975, because Mustang II's with 302 V8's didn't have enough clearance between the oil filter adapter and the cross member to use an FL-1-A.
Mitch, the 428 has the same external engine dimensions that any other FE engine does. In fact, its block is a 352 when first cast.
btw: If your left motor mounts breaks apart, (which while not common, isn't rare either), guess what happens to a vertical mounted oil filter?
The filter may hit the crossmember, and it only takes a coupla hits before the filter cracks open. :-(
Now you have a REAL mess!!
That's why trucks have horizontal mounted filters, and cars have vertical mount oil filters.
Cars have far more clearance, because of the deeper crossmember.
__________________
Bill / Retired Ford Partsman 1962-1997 / Ford Historian / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/1979
1963 Galaxie 500XL / 1965 F100 Styleside Pickup ~ Original Owner / 2008 Fusion S / 2008 Edge SEL
  #5 (permalink)
Old 04-11-2008, 09:49 PM
Pacdaddy Pacdaddy is offline
Pacdaddy is starting off with a positive reputation.
Okay, I've not long been a member and I've seen literally HUNDREDS of posts by you, NumberDummy. At first I thought "Wow. This fella is pretty good." You've taken it to a whole other level with the posts I've read tonight...
My grandfather retired from the FoMoCo plant in Atlanta around '80-'81. He's never mentioned the first thing about unique parts, designs, etc...save for the time he brought some sort of energy consuming black silly putty looking rubber crap from the plant one day years ago. If I remember correctly, you could put this stuff around an egg and smash it with a hammer and the egg not break.
THAT is what bumpers should be made of....
  #6 (permalink)
Old 07-04-2009, 01:42 AM
todd jo todd jo is offline
todd jo is starting off with a positive reputation.
FWIW I ran into this issue while swapping in a 390 into i-6 powered 66 f100. The filter does hit the crossmember. It is not a Ford part and that may be the issue itself. I will search for a FL-300 until I can come up with a different filter adapter!
  #7 (permalink)
Old 07-04-2009, 03:58 AM
Ford Parts Guru
1965/76 F100/350 352/360/390 Oil Filter Adapter
Quote:
C5TZ6881B .. Oil Filter Adapter-Horizontal Type / Obsolete
Fits: 1965/76 F100/350 352/360/390.
PARTS INTERNATIONAL in Farmers Branch TX has FOUR = 888-727-0418.
GREEN SALES in Cincinnati OH has THREE = 800-543-4959.
MILLER OBSOLETE PARTS in Binghamton NY has TWO = 800-546-7278.
JST AUTOMOTIVE in Lebanon TN has ONE = 615-443-3086.
WESLEY OBSOLETE PARTS in Liberty KY has ONE = 606-787-5293.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
