351W balance ? - Ford Truck Enthusiasts Forums
351W balance ?
Old 05-16-2002, 05:05 PM
serian serian is offline
serian is starting off with a positive reputation.
351W balance ?
I recently purchased a 1975 model year 351W
that was originally installed in a E-series
van and later transplanted into a F-series
pickup. Currently, it has a flexplate for
automatic transmission in it, and I want to
convert it to a manual transmission flywheel.
The question I have is this:
What is the balance on the 1975 model 351W ?
The flexplate on this engine seems to be zero
external balance, like the I6-300; I cant find
any additional weights welded to that flexplate
anywhere. The flywheel I have for a 302/351W
has the standard 28 oz balance on it. Did
someone change this engine? or did they just
put the wrong flexplate on and get lucky that
the engine didnt tear itself apart?
Old 05-18-2002, 11:02 PM
Mike W's Avatar
Mike W Mike W is offline
Mike W is starting off with a positive reputation.
351W balance ?
I believe 28oz is correct. Also check the harmonic balancer. I put a mid 80's 302 in an early Bronco and had fun. Had to change the flywheel and balancer.
Old 05-18-2002, 11:54 PM
lvstang lvstang is offline
lvstang is starting off with a positive reputation.
351W balance ?
All 351's are 28oz. Only the 302's changed. Typical Ford! LOL!!
Seems strange about your flexplate. All mine,302 or 351, have a weight welded on.
Old 05-19-2002, 02:08 AM
fever22 fever22 is offline
fever22 is starting off with a positive reputation.
351W balance ?
Flexplate questions andrew's64 1967 - 1972 F-100 & Larger F-Series Trucks 14 08-06-2016 05:50 PM
302 and AOD - vibration?!? TireDood 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 03-25-2015 10:03 AM
351W engine imbalance pg409 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 07-09-2009 05:55 PM
351W ?'s black58 1948 - 1956 F1, F100 & Larger F-Series Trucks 34 12-04-2008 06:25 PM
351 W Balancer and Flywheel question sirianofca Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 7 11-09-2003 12:48 AM
Tags
351w, 50, 58, balance, balancer, balancing, external, flexplate, flywheel, ford, manual, oz, transmission, truck, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
