Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-10-2008, 01:27 PM
saezjose is starting off with a positive reputation.
1.08 carb 2150
i found a 2150 carb 1,08 is on a 8 cylinder pinto, can i use it on a 2.8 6 cyl bronco II it is durasparked, but i need another carb
  #2 (permalink)
Old 04-10-2008, 01:32 PM
tbolt 460's Avatar
tbolt 460 is starting off with a positive reputation.
8cyl pinto?? must be a hot one
__________________
88 BII(208,000mi still going) chop project
90 BII,2.9/C5/D44/9in
86 Ranger Xcab STX 4X4,D35,8.8,456's locked,4in lift
94 Xlporer sport
95 Ranger short bed 4X4 3.0 5spd
http://gearheads.ipbfree.com/index.php?s=&act=idx
  #3 (permalink)
Old 04-10-2008, 01:45 PM
sorry mustang II
  #4 (permalink)
Old 04-10-2008, 03:25 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
Will it bolt up? You may have to fiddle with linkage and fuel hook up.
This is a simple carb, so as long as you hook it up safely--check the linkage for binding and return, make SURE your fuel connection does not leak and doesn't come off or chaf under another part.
If it won't bolt up, find the proper carb, no sense having an adaptor on top of the other issues, just invites trouble.
  #5 (permalink)
Old 04-10-2008, 04:41 PM
thanks i ll probably try it on.
  #6 (permalink)
Old 04-10-2008, 11:37 PM
tbolt 460's Avatar
that carb is gonna be to big. your taking it from a 302 and putting it on a 2.8. you say the 302 one is a 1.08, what is the one on your 2.8
__________________
94 Xlporer sport
  #7 (permalink)
Old 04-10-2008, 11:44 PM
I think the 1.08 is under 300 cfm. There is a chart on here somewhere. The biggest one is barely 400 I think, and the 1.08 is the smallest of the crowd.
  #8 (permalink)
Old 04-11-2008, 09:01 AM
tbolt 460's Avatar
98 = 190
1.01 = 240
1.02 = 245
1.08 = 287
1.14 = 300
1.21 = 351
1.23 = 356
1.33 = 424
he still gonna have to de-jet it. WHAT is the number on the his carb???? find the right one or change it over to the DS
__________________
94 Xlporer sport
  #9 (permalink)
Old 04-11-2008, 02:32 PM
i have already DS. My carb says 1.08 the one on the 8 cyl mustang also says 1.08. on the passenger side of the carb
  #10 (permalink)
Old 04-11-2008, 05:40 PM
Canadianice is starting off with a positive reputation.
Do you think he can take the jets off of his old electronic carb and install them on the Mustang II's 2150 and have a good running carb for the 2.8?
  #11 (permalink)
Old 04-11-2008, 06:29 PM
i no longer have an electronic 2150A, i do have a non elct 2150 now but is cracked by the stud hole and it also binds some times keeping the engine reved up until i press the gas pedal a few times really hard, that's why i like to change it
  #12 (permalink)
Old 04-11-2008, 06:34 PM
Thanks for posting that carb info. I did not know these already used the 2150. It's 45 seconds to figure out if the jets are different. I'd try it as is, but that's easy to say on the internet.
A non-cracked, non-binding carb is a big step up here. Jets, ahh, you can always jet.
  #13 (permalink)
Old 05-01-2008, 11:55 PM
tbolt 460's Avatar
is it runnin yet
__________________
94 Xlporer sport
  #14 (permalink)
Old 05-14-2008, 11:01 AM
it is runing now. however i parked it to check on a noise that developed, my friend thinks is the crankshaft bearings, i,ll pull the engine saturday and check them. I tryed to check by removing the oil pan but it is near to imposible to remove the pan with the eng still in, so i want to clean and paint the eng compartment anyway, but yea i dont want to run it until i find out what it is that noise
  #15 (permalink)
Old 05-16-2008, 01:41 AM
1BadB2's Avatar
1BadB2 is starting off with a positive reputation.
ive been running my 2.8 on a 302 carb for quite some time... but instead of making a new post perhaps i can post in here... i am moving back up into high altitude. 6000ft average. what size jets should i use?
im using 2150 carb, K&N filter with 10" round edelbrock open filter box
duraspark ign
70s mustangII/Pinto heads (no smog)
2.5" exhaust, catco cab, flowmaster 40 delta flow
quite a few other mods... but not sure that any of them matter.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
