01 lightning problem
Hey, was just wondering if anyone has had problems with there supercharger belt chewing up the front rib. I have had the truck for about a year and keep having this problem. I have replaced all the oem pulleys and the tensioner, nothing has helped it. I have talked with the local ford dealership and they mentioned it could be the crank pulley. The belt seems to be sitting on the front of the crank pulley and the back of the supercharger pulley. Another question is if I replace the crank pulley I am probably going to put on a #4 pulley. other then a bigger intercooler the truck is stock. If I put that pulley on should I also do a Tune on the truck, or will it be allright to run for awhile. After a few more mods, I am going to anyways, but thats down the line. Thanks guys.
on
What's the condition of the supercharger? Bearing condition? Any play up/down or front/back on the top pulley when there is no belt installed? And nicks or chips on the lower pulley? Does the lower pulley wobble much (a little is normal) when the engine is running?
If you run a 4lb pulley I highly recommend you get a good custom tune for it. With 2lbs you ought to be just fine with the stock tune.
