Lowering a 2WD 1994 F150 - Page 2 - Ford Truck Enthusiasts Forums
Old 06-01-2008, 09:33 PM
crestfallinman's Avatar
crestfallinman crestfallinman is offline
crestfallinman is gaining momentum as a positive member of FTE.
how is the 2/4 inch drop workin?
i have heard alot of things about it that werent so good
Old 06-01-2008, 10:06 PM
dan91ford150 dan91ford150 is offline
dan91ford150 is starting off with a positive reputation.
Quote:
Originally Posted by TexasGuy001 View Post
Dan91ford150,
Just get a set of 2 inch drop shackels. They are about 30-40 bucks. That is what I am going to be doing to mine. Its much easier and you retain the factory payload.
I know that most people would like to mantain their factory payload, but I was hoping to achieve a better ride...
Old 06-01-2008, 10:20 PM
oobical oobical is offline
oobical is starting off with a positive reputation.
when you lower the truck make sure that you get your front suspension right because if you have that twin i-beam setup they can be a hassle especially when changing the stock height either way.
Old 06-02-2008, 04:17 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
The 1-2 inch drop shackels are not that hard to put on. You don't have to drill any rivets. You just need some jack stands and a floor jack. Well you also need a couple of wrenches.
Old 06-02-2008, 08:59 AM
spidermonkey's Avatar
spidermonkey spidermonkey is offline
spidermonkey is starting off with a positive reputation.
Crestfallinman, my 2/4 drop has been text book perfect. Belltech kit. went on at 18K miles, truck now has 175K miles. no issues. Probably the best aftermarket thing I have ever purchased.
Old 06-02-2008, 10:20 AM
sounds good i will have to order it soon, my truck is too high lol
Old 08-17-2008, 07:32 PM
motopsyko32's Avatar
motopsyko32 motopsyko32 is offline
motopsyko32 is starting off with a positive reputation.
Quote:
Originally Posted by nintey4f150 View Post
i got a 4/6 drop on my 94 f150..... belltech beams with one inch drop springs and a belltech flip kit in the back... and no you cannot cut the springs on a 92-96 f150
http://i138.photobucket.com/albums/q...7/truck007.jpg
how does it ride?
Old 08-17-2008, 09:07 PM
nytling92 nytling92 is offline
nytling92 is starting off with a positive reputation.
I did the 5/7 on my 92 flareside back in 93. It has a great ride and factory payload, but I wouldn't haul anything that heavy anyways. I reatained the front and rear sway bars so it handles good also. One thing to watch out for, and I had to do this to mine, if you do a 2" in the front with a spring you really need to get the offset camber bushings. 2" puts a strain on the ball joints or at least puts them very close to the end of travel. This goes for just doing a 2" drop or a 5", as these 2 use a 2" spring, a 3" drop uses just the dropped I-beam, the 4" drop uses the beam with a 1" spring. A good front end alignment shop will know what you need and be able to do it for you. I wish I had pics to share with you but my truck is in Mo. and I'm in Ky.
By the way niety4, I love your truck and the way it sits. These trucks look great lowered it is really a shame more haven't been done.
Old 10-21-2008, 01:08 PM
Thumper19's Avatar
Thumper19 Thumper19 is offline
Thumper19 is starting off with a positive reputation.
So this may be a late question but I have an 89 F150 that I just did the drop I beams on and Im wanting lower. When I did the drop I noticed at stock height my passenger side sat lower than the driver side about a 1/2in.. Now it sticks out like a soar thumb and the passenger side sits way lower than the driver side.. Im wanting to do drop coils but I dont know which ones I should get.. I can get either a 1" or 2" drop coil but since I have to shim the lower side up(Passenger side) Im wanting to know if anyone would know which set of drop coils I should get or if it is even possible to do drop coils because a DJM guy told me its not worth it cuz its hard to align but then Belltech said it can be done and wouldn't be that hard.. Ninety4 I have lots of questions for ya man so if you could please help let me know..
I only have the front dropped right now
Old 10-21-2008, 04:21 PM
I would look at getting the new coils. Unless your frame is bent the only other logical problem would be your springs are sagging, but this could also be caused by the rear leafs. I think you can put the front frame horns up on jackstands so that the front tires don't touch the ground, leaving the rear wheels and weight on the back, and see if it leans. Then do the opposite end and check the same thing. You should be able to figure out which end is giving you the lean.
If you have 3" dropped beams and you have had no problem aligning it 1" coils should not be a problem. As I stated above if you go 2" coils on either stock or dropped beams it is a wise idea to get the offset camber bushings. You may not have to but this will help ensure you do not bind the ball joints to achieve proper alignment.
Hope this helps.
Old 10-21-2008, 04:36 PM
Thumper19's Avatar
Oh ok thanks... Yeah Im thinking it has to do with my rear leafs for it not being leveled.. I had put new stock height coils from moog racing that are progressive rate coils and it was still off.. So Im hoping that since I ordered new rear leafs, when I do the flip kit for the rear it makes the truck look level.. But other than that I don't know what else it would be other than the frame being bent.. Which I hope it isn't
Old 10-22-2008, 03:13 AM
Its fairly common for our trucks to not sit perfectly level. Mostly they sit lower on the passenger side. I think its becuase the engine is not centered in the truck. It sits farther to the passenger side. I suppose some sit lower on the driver side because of worn out springs if the previous driver was a real heavy person.
  #28
Old 10-22-2008, 06:54 PM
Jason Lewis's Avatar
Jason Lewis Jason Lewis is offline
Jason Lewis has a good reputation on FTE.Jason Lewis has a good reputation on FTE.
Mine has the left side bed lean i think its because of the gas tank over the years after fillup and fillup.
  #29
Old 10-22-2008, 08:17 PM
SuperSnake's Avatar
SuperSnake SuperSnake is offline
SuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to behold
What did you have to do for those 2nd Gen SVT Lightning wheels to work?
  #30
Old 10-23-2008, 12:39 AM
StealthWyvern StealthWyvern is offline
StealthWyvern is starting off with a positive reputation.
Quote:
replica wheels
rear leaf spring install 93F150&69Stang 1987 - 1996 F150 & Larger F-Series Trucks 9 11-28-2015 02:31 PM
Rear leaf springs Fasttrax 2015+ F150 10 08-22-2015 11:26 AM
1975 E-150 full suspension replacement questions Funke1 1968-2013 Full Size Vans 1 07-28-2015 02:41 AM
Strut Spring Compressor amorican88 2004 - 2008 F150 1 04-30-2015 02:44 PM
standard 4X4 ride height tastyklair 1973 - 1979 F-100 & Larger F-Series Trucks 7 12-20-2005 02:34 PM
Tags
1987, 1993, 1994, 1995, 95, 96, drop, f150, kit, kits, lower, lowered, lowering, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
