1994 Ford F150 4x4 Tires and rims - Ford Truck Enthusiasts Forums
Old 04-10-2008, 11:10 AM
jac43k jac43k is offline
jac43k is starting off with a positive reputation.
New here with a few questions, I would like to replace my stock tires and rims on 1994 Ford F150 4x4 from 235/75r15 too 30/9.5R15, not sure if this tire will be bigger? second not sure of the bolt pattern? Any help would be great, thanks
James
Old 04-10-2008, 11:21 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
These trucks have 5 x 5.5 bolt pattern. Stock tires size is about 28" diameter, 30 x 9.5 will be about 30" on a similar 7.5" wheel. This will change the total gear ratio of the vehicle, whether it's a positive or negative change depends upon the axle gearing and engine combo.
Old 04-10-2008, 03:12 PM
gweeds's Avatar
gweeds gweeds is offline
gweeds is gaining momentum as a positive member of FTE.
If you get it set up and it doesnt work, you can raise the bumper up a little and put two thick lock washers behind it, gives you a little more clearance. Is trimming the bumper an option for you?
Old 04-10-2008, 03:52 PM
Conanski's Avatar
These size tires fit on an F150 4x4 no problem.. just happens to be the exact size tire I have on my truck right now. I have also had 31x10.5 tires on 8" rims on this truck no problem, and have seen 32x11.5 tires on these trucks.
Old 04-10-2008, 06:14 PM
95F350XL 95F350XL is offline
95F350XL has a good reputation on FTE.95F350XL has a good reputation on FTE.95F350XL has a good reputation on FTE.
33x12.5 is the biggest you can go, but you have to trim the inner bumper lip. Id go 31x10.5 they will look alot better then the 30's
Old 04-10-2008, 08:57 PM
builtfordtough13's Avatar
builtfordtough13 builtfordtough13 is offline
builtfordtough13 is gaining momentum as a positive member of FTE.
I have 31x10.5 BFG All Terrain KO's on the stock rims and love them, they fill up the wheel well nice and didn't lower my gas mileage or anything. They also ride and handle nice.
Old 04-10-2008, 09:58 PM
Kista20's Avatar
Kista20 Kista20 is offline
Kista20 is starting off with a positive reputation.
I am running 31x10.50 firestone destination at's on mine, the neighbor has 33x12.50's on his, both oem wheels just like in builtfordtough's picture
Old 08-19-2016, 03:55 PM
Reptillian324 Reptillian324 is offline
Reptillian324 is starting off with a positive reputation.
Quote:
Are your rims oem? I'm about to buy the truck mentioned in this thread and the current tire size is 31x10.5OR15LT but if they are the stock rims then my 235/75/15 tires should fit right? Could you send a picture of your rims if they are the stock ones?
Old 08-19-2016, 05:19 PM
GoinBoarding GoinBoarding is offline
GoinBoarding is gaining momentum as a positive member of FTE.
I don't think I'll ever run less than 33x10.5 again but I like to explore the mountains in the fall. I have them mounted on stock wheels, with about 1.5" lift up front and bumper spaced 0.5". I don't tow much though. I'd run LT235/75R15 if I were still towing heavy.
Old 08-19-2016, 09:21 PM
96F150-4.9 96F150-4.9 is offline
96F150-4.9 is starting off with a positive reputation.
Or you can call it a day and get some 35"
rims are 17x9
Old 08-19-2016, 10:46 PM
Dirt racer's Avatar
Dirt racer Dirt racer is offline
Dirt racer is starting off with a positive reputation.
Just wondering if you know this thread is 8 years old
Old 08-20-2016, 12:09 AM
Quote:
Ha! I didn't catch that either.
Old 08-20-2016, 12:36 AM
It's Alive! It's ALIVE!
Old 08-20-2016, 10:51 AM
My4Fordtrucks's Avatar
My4Fordtrucks My4Fordtrucks is offline
My4Fordtrucks is starting off with a positive reputation.
Quote:
Originally Posted by Reptillian324 View Post
......I'm about to buy the truck mentioned in this thread.....
Well yes and no that it is an old thread.
Tires-Help! epercy61 1997 - 2003 F150 2 09-05-2015 03:11 PM
Rim help SC78f150 1973 - 1979 F-100 & Larger F-Series Trucks 7 01-15-2014 08:56 PM
What is the biggest tire I can fit on a stock 4X4 F150 jdhudall 1987 - 1996 F150 & Larger F-Series Trucks 2 08-12-2006 09:24 AM
Best rim size for 32x11.5 tires? DaddyOutlaw Brakes, Steering, Suspension, Tires, & Wheels 5 03-28-2005 10:00 PM
Mickey Thompson Baja Belted Tepot Brakes, Steering, Suspension, Tires, & Wheels 6 11-28-2004 08:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
