Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-10-2008, 09:35 AM
fenix1 is starting off with a positive reputation.
Engine overheated the other day and went to hittin' on 5 cylinders. Shut it off let it cool down for 30 minutes. Took thermostat cover off...stuck shut. Trashed it and replaced thermostst cover. Filled it up with water and drove it home bout 10 miles. Anyway, drained crankcase and was NO water in the oil. Then drained what water was left in radiator...NO oil in the water. Pulled plugs and ran compression check...hardly any on #1 cylinder. QUESTIONS: If heads are O.K. should I just replace the gaskets! Or, since I got that engine hotter than a firecracker just go ahead and replace gaskets and get new heads? Knowing if I pull the heads gonna break the exhaust manifold bolts; what size, type, and grade bolts are they? Any help would sure be appreciated!!!
The vehicle is an 88' Bronco II with a 2.9 5 speed. Real FUN thing to work on!!!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-11-2008, 09:27 AM
TigerDan's Avatar
TigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud of
I'd pull the heads and check them for cracks very carefully, and be prepared for the worst. Here's a little article about replacing 2.9 heads:
2.9 Ranger Head Replacement .: Articles
And don't assume that you'll break manifold bolts, I got lucky and didn't break any though it wouldn't really have mattered since I was replacing the heads anyway. A good soak overnight with PB Blaster or some other good penetrant might help.
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
