Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
Closed Thread
  #76 (permalink)
Old 04-10-2008, 10:02 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE.
Quote:
Originally Posted by crazyredneckanyhow View Post
well heres osme tech for ya fishy. Any idea what the wheelbase of an EB is?
Ryan i got an idea to keep ya from bein bored. ANSWER MY EMAIL!
what email?
__________________
2007 Lariat screw - White Sand Tri Coat - chrome package - Black leather captains chairs - sunroof - audiophile - 20" Mark LT wheels - Color Matched Door handles -
2005 XLT scab -
1995 xlt scab - 13 inches of lift - SAS
Needed: 2004-2008 OEM cat back for F-150 supercrew
  #77 (permalink)
Old 04-10-2008, 10:13 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow crazyredneckanyhow is offline
crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of
i sent ya an email through FTE. Bout your SAS with the newer style arms
__________________
Just another zombie. my rig:
09 f-150 6" body lift, TTB front,stacked rear blocks,BFG A/T, Fuzzy Dice
Ok so apparently some small minded people dont understand that the truck in this signature is a combination of many sarcasims. Please quit being stupid and study up before you run your mouth about it.
  #78 (permalink)
Old 04-10-2008, 10:31 PM
STGFordCrazy04's Avatar
STGFordCrazy04 STGFordCrazy04 is offline
STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold
Fishy,
why do you have 3 monitors?
Karl,
they werent expensive. Item # 760-68054 from Jegs $14.99. I didnt even check felpros price.
I think Im going to do some work on my stealth when I tear the motor down. Post some after pics if you dont mind. Better yet put it in your head porting thread.
__________________
Kris
Please do not PM me. My email is STGCountryboy312 at AOL dot COM
Quote:
Originally Posted by thorseshoeing
Yes you are the anti christ...
  #79 (permalink)
Old 04-10-2008, 10:53 PM
Ryan50hrl's Avatar
Dude....check post 44 in this thread...
__________________
2005 XLT scab -
  #80 (permalink)
Old 04-10-2008, 11:39 PM
captain p4's Avatar
captain p4 captain p4 is offline
I'll sleep when I'm dead
captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold
Quote:
Originally Posted by fishmanndotcom View Post
i have been wondering.... am i the only one running three computer monitors here? i'm worried work is making me too geeky
-cutts-
I have a 27inch monitor
I run duals sometimes with the laptop and the 27inch.. but normally just the gigantor one by itself.
taking a break from brakes. soft pedal.. new front pads, bled the brakes, and now I adjusted that little rod inside the master cylinder, it got a little better... any other ideas? I think i'm going to turn the rod out a little more and see what happens .. whats the right amount to adjust this thing by? I just did one complete turn..
__________________
-Paul
-88 Mustang 5.0/5spd mild restoration in progress
-78 Bronco 460, c6, np205, d60/sterling10.25, OBA, 36" hummer tires, 10 ptroll cage, some other stuff
-2003 F350 Supercab shortbed FX4 6.0 PSD
  #81 (permalink)
Old 04-10-2008, 11:56 PM
chrono4's Avatar
chrono4 chrono4 is offline
chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all
I gots 2 right now. but only a 17 and a lcd 17
__________________
--Andrew--
Rocking a 79' f150 with a 300 and a 4 speed........
Full York OBA Install
Welding a 9"
Very simple front bumper
Lowering Spring Towers
Hi, I'm Andrew and I have a wheelin problem that is often disrupted by fabbin and drinkin, glad to meet yall.
Technical Advisor
  #82 (permalink)
Old 04-11-2008, 12:24 AM
captain p4's Avatar
ok, so if i found a huge vacuum leak would that explain a soft pedal?
__________________
-Paul
  #83 (permalink)
Old 04-11-2008, 12:37 AM
chrono4's Avatar
No, low vacuum would cause the pedal to be harder than normal. What about the rears? Have you adjusted them and bled them too?
__________________
--Andrew--
Welding a 9"
Technical Advisor
  #84 (permalink)
Old 04-11-2008, 12:44 AM
captain p4's Avatar
yeah, bled all 4 corners. I did not adjust the rears though.. I have to spin that thingy through the hole.. until it just barely grabs when I spin and then back off a little?
I adjusted the rod a little more and the pedal got a lot better, but it still doesn't feel quite right.
Would a vacuum leak cause a high idle? One of the plugs for the splitter that comes off the manifold in the rear is missing or fell off somehow.
I just need enough brakes to get me though wheelin saturday.
__________________
-Paul
  #85 (permalink)
Old 04-11-2008, 12:46 AM
chrono4's Avatar
Yeah, the leak would cause a higher idle. Yeah, thats how you adjust them.
If you get it to where you're positive there is no air in the system, and everything is adjusted right, and you still have problems, I would bet some rubber lines are to blame.
__________________
--Andrew--
Welding a 9"
Technical Advisor
  #86 (permalink)
Old 04-11-2008, 12:51 AM
dragogt's Avatar
dragogt dragogt is offline
dragogt has a very good reputation on FTE. dragogt has a very good reputation on FTE. dragogt has a very good reputation on FTE. dragogt has a very good reputation on FTE.
yep, and if the lines are good than the mast cylinder is bad.
__________________
92 Isuzu Rodeo 5sp 4x4
87 F150 lwb
83 bronco
86 mustang gt t-top
83 mustang gt
Aaron -STG's - Pirate Investigator
Quote:
Originally Posted by captain p4 View Post
If you can't tell if you have a body lift or not maybe you shouldn't be giving people advice in the offroad forum????
  #87 (permalink)
Old 04-11-2008, 12:53 AM
captain p4's Avatar
I have braided stainless everywhere but from the hard lines to the front calipers .. but they're probably the original lines.
As for bleeding.. you open it, have someone step on the pedal, close it and then they let go, repeat until no air comes out? Just making sure I was doing it right - driver front, passenger front, driver rear, passenger rear was the order we did it in if that matters.
__________________
-Paul
  #88 (permalink)
Old 04-11-2008, 12:57 AM
dragogt's Avatar
that it, but it's usually best to start at the wheel furthest from the mast cylinder, so and so forth.
__________________
87 F150 lwb
83 bronco
86 mustang gt t-top
83 mustang gt
  #89 (permalink)
Old 04-11-2008, 01:04 AM
MBBFord's Avatar
MBBFord MBBFord is offline
MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold
You bleed the lines right, but the order wasn't...
Some people say the order doesn't matter, others do.....
I usually follow the correct order b/c I'm to lazy to do it twice if another doesn't work, but anyway, you're suposed to start at the wheel farthest from the master cylinder/booster.
So:
Passenger rear
Driver rear
Passenger front
driver front
Don't know if it 'really' makes a difference if you don't follow it.
Vacuum leaks are a pest to track down, and can cause several problems....
__________________
79 Bronco 400 C6 NP205 D44 9" 4.56 gears Lockers 6" lift and 37" SS Iroks
77 F-100 302 C4 D44 31" M/Ts
04 F150 Lariat Screw 4x4 2"AS 32x11R17 Hankook M/Ts or 34x10.50-17 SS LTBs
  #90 (permalink)
Old 04-11-2008, 01:05 AM
captain p4's Avatar
which way do I spin the thingy for the rear drums?
__________________
-Paul
Closed Thread
Tags
coilsovers , ranger , wwwford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
