Andrew,
you might do some reading on Fordsix.com but IIRC 300s dont react well to super chargers. Generally speaking a SC needs/wants RPMs to build boost and as you know most 300s never go above 3500rpm and are pretty much flat above 2800-3000rpm.
Id stick with the turbo idea personally.
__________________
Kris
Please do not PM me. My email is STGCountryboy312 at AOL dot COM
Andrew,
X2! With the low end torque that you want for a good offroad rig, the turbo setup will work for you much better. You'd be making that 300 scream getting the rpms up high enough to make the SC effective.
__________________
Karl
I'm the Voice of Reason
FTE - Where signatures get edited with no explination why.
Well, today is the day. Im about to head off to work and drop the engine in. Hopefully Ill have it running around lunch time.
My next project will be 3.00 gears to offset the increased horsepower. Gotta keep wheel speed up!
Sounds gooooood.
Actually, IF I were you, I'd run 2.75 gears.
Think about it, good cruising RPMs on the hwy when you go to the mall, and when you go off road, put it in 4 Lo, and you'd actually be geared pretty good for 40s. haha
__________________
79 Bronco 400 C6 NP205 D44 9" 4.56 gears Lockers 6" lift and 37" SS Iroks
77 F-100 302 C4 D44 31" M/Ts
04 F150 Lariat Screw 4x4 2"AS 32x11R17 Hankook M/Ts or 34x10.50-17 SS LTBs
Andrew,
Oh I wouldn't run the s/c on the 300 if for some crazy reason I ran into one. turbos sound cooler anyway
Mornin minions!
Kris: Video will be neccesary, as will alot of pics!
Andrew: The s/c 300 would be rather awesome as i have NEVER seen one, but i think everybody else is right in saying you cant beat the sound of a turbo!!!!
__________________
Don
I like bacon.
95. f250 4X4. "stock" 5.8l mated to a zf 5speed.
37" good years and some fender trimmin.
