Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
Closed Thread
  #601 (permalink)
Old 04-17-2008, 09:21 PM
Truckin4life Truckin4life is offline
Truckin4life has a great reputation on FTE. Truckin4life has a great reputation on FTE. Truckin4life has a great reputation on FTE. Truckin4life has a great reputation on FTE.
Quote:
Originally Posted by chrono4 View Post
So I built this big table top kicker jump for my back yard to help me in setting up my shocks on the wheelers. Well I got this smart idea to drive my truck up it. Well, I got up on it without it breaking, got out to get a picture, and crack, no more jump.
been there done that... not fun...
__________________
Don
I like bacon.
95. f250 4X4. "stock" 5.8l mated to a zf 5speed.
37" good years and some fender trimmin.
Life is short. Play hard!
  #602 (permalink)
STGFordCrazy04's Avatar
STGFordCrazy04 STGFordCrazy04 is offline
STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold
its an open 1" spacer on top. I didnt touch the divider except to touch up some casting flaws
__________________
Kris
Please do not PM me. My email is STGCountryboy312 at AOL dot COM
Quote:
Originally Posted by thorseshoeing
Yes you are the anti christ...
  #603 (permalink)
Old 04-17-2008, 09:22 PM
kjett's Avatar
kjett kjett is online now
kjett has a great reputation on FTE. kjett has a great reputation on FTE. kjett has a great reputation on FTE. kjett has a great reputation on FTE. kjett has a great reputation on FTE.
Oh, and about your headers, check here to see if he still has these L&L headers:
460ford.com :: View topic - Headers for sale... L&L, 73-79 4x4......
You should be able to make them fit with very little persuasion.
__________________
Karl
I'm the Voice of Reason
FTE - Where signatures get edited with no explination why.
95 F-150
1995 F-150
Ranger build: Ranger Mud Truck
http://i209.photobucket.com/albums/b...kjett/baby.gif
  #604 (permalink)
Old 04-17-2008, 09:25 PM
kjett's Avatar
Quote:
If you read what Randy wrote to me, he said when using the open spacer, round out the top of the divider to sort of split the air, as the flat square edge will create some unwanted turbulence when the air/fuel mix tries t ofigure which way to go into the intake. Just some more stuff to think about.
__________________
Karl
95 F-150
1995 F-150
  #605 (permalink)
Old 04-17-2008, 09:27 PM
littleme13's Avatar
littleme13 littleme13 is offline
littleme13 has a good reputation on FTE. littleme13 has a good reputation on FTE.
Quote:
Originally Posted by countryboy116 View Post
that would work i guess, just the thing im worried about is im just learnin how to weld, how hard is it to weld that to get the proper penitration and all, of course my dads buddies real good and hes teachin me but i could always get help from him, or maybe i could just run the full length axles under there, would get better stability and all like matt said, id just have to do a little fabbing to make the spring perches line up and all
only thing to consider when going full size is how far your tires are gonna stick out. some flares will take care of that usually. with going leaf springs just stay away from the 78 and 79 44s i think it is. they would work but not as well. then just buy some spring perches set your pinion angle and weld them on. coil springs for the most part are a no brainer if you do your research. use stock radius arm brackets and arms and then your spring buckets can be adjusted to work. wait is the ranger coil or torsen arms im not sure on the 2wheel drives.
  #606 (permalink)
Old 04-17-2008, 09:29 PM
Karl,
my headers are L&L 77.5-79 F250 frame exit headers. Im pretty sure these would be the same but just not meant for my truck. All my searching has found zip in the aftermarket for 2"-2 1/8" headers without going custom made.
Didnt you read that removing any part of the center divider would hurt performance on a dual plane intake?
__________________
Kris
  #607 (permalink)
Old 04-17-2008, 09:34 PM
kjett's Avatar
Yeah, but I talked with him offline about the spacer issue (2" 4 hole and 1" clover), and that 's when he said not to cut it down as it would hurt performance, but rather smooth out the top to divide the flow better. For your street/strip motor, and only the 1" spacer, I don't think it will do much for you, where with me going a full 3" over the pad, I need all the direction I can get to keep the air speed up and moving to feed the high rpm cam.
__________________
Karl
95 F-150
1995 F-150
  #608 (permalink)
Old 04-17-2008, 09:36 PM
kjett's Avatar
Speaking of moving on, did you hear the Monsterbaby did in fact sell that nasty ranger of his! It sort of made me sick when I saw over on 460ford that he was selling a bunch of his race stuff.
__________________
Karl
95 F-150
1995 F-150
  #609 (permalink)
Old 04-17-2008, 09:38 PM
countryboy116's Avatar
countryboy116 countryboy116 is offline
countryboy116 has a very good reputation on FTE. countryboy116 has a very good reputation on FTE. countryboy116 has a very good reputation on FTE.
Quote:
im not sure about that, havent payed much attention to the suspension on this one haha, im sure a set of fener flares will do the job if i go full length axles, im really thinkgin about going that route now, so you're saying coils and rad. arms would be easier? hm i may just do tha then, id get better flex outta good coils too im sure
__________________
-Mike
MINION-Rebel Peon
'97 F150 4x4 DD for now
-SOON: D44HD/sterling 10.25, 4.10s, 36s
...Just a Good Ole Boy
IN TOO DEEP Offroad Club!
  #610 (permalink)
Old 04-17-2008, 09:40 PM
Karl,
here is a great writeup Charlie Evans did on 460ford.com. This made me sort of rethink my opinions of "needing" larger headers.
as you can read he tested 2" vs 2 1/4 primarys on a TFS headed 557 (drool!)
below 5300 rpm the 2" headers gave more power and above 5400 the 2 1/4s were better.
For my build wanting max power below 5800rpm it seems I may be better with the headers Ive got. The 3 or 4 hp Ill gain at the flywheel above 5400 will not be worth sacrificing the hp Ill loose down low
__________________
Kris
  #611 (permalink)
Old 04-17-2008, 09:43 PM
He didnt want an awful lot for it. Id bet you wouldve come out much better buying his truck and droppin the motor in than building your truck from scratch.
__________________
Kris
  #612 (permalink)
quadzjr's Avatar
quadzjr quadzjr is offline
just another Rockwell looser
quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE.
Karl,
X2.......2" ers are plenty for your build......
__________________
Nick
STG's Minions: Sergeant at Arms
The Rockwell/4-link/anything Badass Specialist!
Dont be a puss, RUN ROCKS!!!!
Quote:
Originally Posted by Ebay Assjack View Post
The truck was lifted with the custom frame as seen in pix. (the best way to lift a truck!!!)
My Build: 96' f150 4link 2.5 tons etc etc etc....
  #613 (permalink)
Old 04-17-2008, 09:44 PM
yeah but Ive only got 1 3/4s now
__________________
Kris
  #614 (permalink)
Old 04-17-2008, 09:46 PM
460ford.com :: View topic - Header sizes for OEM style alum. aftermarket heads
here is the link. apparently Im an idiot and didnt post it in the first post
__________________
Kris
  #615 (permalink)
kjett's Avatar
Karl,
I read that article and meant to pass it alongto you for reference. I was sort of wondering how my 2 1/8 tubes would do with my relatively small motor, and knowing that I will live most of my time between 4-6k rpms, it sort of put me to ease that they will work out just fine for my needs. Opposite worlds collide!!!
__________________
Karl
95 F-150
1995 F-150
Closed Thread
Tags
coilsovers , ranger , wwwford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
