Grounding strap... - Ford Truck Enthusiasts Forums
Grounding strap...
Old 04-09-2008, 09:48 PM
ottawaguy's Avatar
ottawaguy ottawaguy is offline
ottawaguy is gaining momentum as a positive member of FTE.
Grounding strap...
I found a ground strap today in the engine compartment that is attached to the firewall directly in front of the passenger seat. The other end is not connected. Is this an engine ground strap? I could post a pic, but I'm sure most will know the strap I speak of.
It has a flat loop at the loose end I believe...so I'm guessing a bolt came loose somewhere.
Can someone tell me where it connects to?
Many thanks
Old 04-10-2008, 04:35 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
If it is just above the heater box, it goes to the hood. I have the same thing and it broke in half. It is still connected on each end. It has been this way for a while. I tried to join it back together a few times but it never stayed. I don't know what it is for. Look on the hood and see if there is a rivet near that location. I was thinking about drilling out the rivet and replacing the ground strap.
Old 04-10-2008, 05:54 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
If the hood strap is still there, the other grounding wire at that same bolt on the firewall goes to the engine -- most likely a bolt on the intake manifold.
Old 04-10-2008, 08:49 AM
I just looked at mine and the ground from the engine (intake bolt) to the firewall is separate and has its own bolt. If that is what is broken on yours, I would fix that.
Old 04-10-2008, 10:13 AM
ottawaguy's Avatar
Here is a pic of the strap in question...the attach point on the firewall is circled.
Now I don't see a strap to the hood...but I don't see a grounding strap to the engine either.
Old 04-10-2008, 07:19 PM
The strap on the hood is by the hinge not to be confused with the spring. You can barely see it in you picture. It looks like your hood strap is attached. The strap in your picture that is not connected to anything goes on the bolt/stud on the bracket between the exhaust manifold and the upper intake.
Old 04-10-2008, 08:47 PM
EPNCSU2006's Avatar
I agree...based on the size of the eyelet, it should connect to a bolt on the intake manifold.
Old 04-10-2008, 09:12 PM
icrman icrman is offline
icrman is starting off with a positive reputation.
I'm too lazy to run out an look, but I think its conneted to the brackets that hold the AIR system hoses etc. I remember disconnecting and hooking one up there.
Grounding Straps/Wires--How Many? kindorotten 1973 - 1979 F-100 & Larger F-Series Trucks 24 08-21-2016 11:18 AM
Hood ground loop question Millam 1967 - 1972 F-100 & Larger F-Series Trucks 5 08-05-2015 12:05 AM
ground strap question 66ca 1987 - 1996 F150 & Larger F-Series Trucks 13 06-20-2010 07:27 PM
Ground Strap- Where does it go? EHC112 1987 - 1996 F150 & Larger F-Series Trucks 8 11-02-2009 06:28 AM
Engine bay small ground strap? H2OnO2 1978 - 1996 Big Bronco 6 03-19-2009 05:55 PM
Tags
05, 1994, 1995, broken, bronco, engine, f150, f350, ford, ground, grounding, locations, main, strap, straps, truck, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
