Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-09-2008, 07:59 PM
planewood is starting off with a positive reputation.
Flathead Six chrome air cleaner???
I just put a Holley 897 carb on a "H" series flathead six (226 cid) and I'd like to put a chrome air cleaner / paper filter on top of it. However, this carb uses the special V shaped clamp instead of a center hold-down bolt. Throat size at the top of the carb is 2-5/16" OD. From there it goes down about 1/4" then flares out to the V which is about 2-3/4" at max.
Need one that is low-profile cause I only have about 2.5" clearance above the top of the carb.
Any ideas??
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-15-2008, 01:05 AM
Snowking's Avatar
More Booze Less Guilt
Snowking is gaining momentum as a positive member of FTE.Snowking is gaining momentum as a positive member of FTE.
I don't remeber clearence being a issues just the width and adapter plate are sold so you can put a air cleaner with a 4 inch opening (example) and the adapter plate permits to sit on a 2 5/16 carb.
Hopefully this is a answer I had a little trouble in your wording.
__________________
only the finest junk around
2000 Ford F150 Supercab
1946 and 1947 Mercury 1/2ton
1949 Mercury M47
1951 Mercury M-6
1952 F-1
1953 F250
1956 Ford F100
1957 F250
1964 Mercury M100
1967 & 69 F100
4 old Internationals/ Dodges (Hey, Nobody's perfect)
  #3 (permalink)
Old 04-15-2008, 10:17 PM
effie_man's Avatar
Fatty driving the Flatty!
effie_man is starting off with a positive reputation.
there should be lots of aftermarket cleaners to use just have to cruise the net a bit until you find one you like
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
