05 F-150 5.4 spark plugs - Ford Truck Enthusiasts Forums
Old 04-09-2008, 06:38 PM
bigdogk9 bigdogk9 is offline
bigdogk9 is starting off with a positive reputation.
Well I finally got the guts to pull the plugs.I bought the remover tool and the rethreader kit and the champion plugs.Only needed the plugs though.They all came out.I did them early @29k so I thought they where very hard coming out took my time and followed tsb and all came out.Cant see waiting longer than 30k and expecting them to come out.Added 2mpg and truck runs just as good as with the motorcraft plugs in it.Engine temp I think is the main key.
Good luck to all.
Old 04-09-2008, 07:09 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
Don't see how the plugs could add 2 mpg unless you've been running bad (cheap) gas and fouled the factory plugs. Can you post a picture of what the stock plugs looked like? When Champion comes out with a colder version of the plugs I'm going to buy a set for my supercharged truck. Brisk has a one piece plug for it but they require changing about every 25K and its a PIA to change them.
Old 04-09-2008, 07:47 PM
They looked pretty worn already .I already tossed the plugs but they had a reasonable amount of carbon on them .I had and still have not the best idle a very small bounce dont know if this is comman but seems to run o.k.The mpg before was 9.4 now around 10-11 is that goodm for this truck just got it.went from chevy to ford to get all the horror stories.
Old 04-09-2008, 07:56 PM
Joe04F150 Joe04F150 is offline
Joe04F150 is starting off with a positive reputation.
Damn I thought the 12.8 MPG I'm getting was bad.
Old 04-09-2008, 08:06 PM
JimTex JimTex is offline
JimTex is starting off with a positive reputation.
The differences we encounter are really amazing. My dealer changed my plugs at 65,500 and had no problems. The truck was running great before and I can tell no difference. Also, same gas mileage. My old plugs were a little discolored but otherwise looked perfect. No wear at all. I run Shell, Texaco and Conoco, all gas with good detergents. One other thing that probably makes no differenc, for the last 36,000 miles, I had a tuner on it, the Edge.
Old 04-09-2008, 08:18 PM
I think if you follow tsb its doable.it seemed to me that temp was a major factor let engine get to cool and plugs just stop turning.and as for the mpg thing what is norm for a 05 screw
Old 04-09-2008, 09:40 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
asking what is norm for mileage is about as good as asking what religion is right....you'll never get an answer that sticks.....your mileage is about as low as i've heard of...i average around 14....and i've heard of people getting average around 16
Old 04-09-2008, 09:50 PM
4x4s don't get as good as 4x2s, plus wheels size and tires, the area you drive, all kinds of factors. I have the 4x2 XLT Supercrew with 3.55 gears. I get 16.5 to 17 around the Dallas/Fort Worth area. On the highway, I get 18.8 to 19.2 driving 75 to 85 mph.
Old 04-09-2008, 11:07 PM
patriots6800 patriots6800 is offline
patriots6800 is starting off with a positive reputation.
Iget around 15 mpg on my 04 4x4scab according to my edge custom bent exhaust, everything else stock i think its a little higher than that where is this tsb and what is this special removal tool everyone is talking about
Old 04-10-2008, 10:28 AM
F0rdzTuff F0rdzTuff is offline
F0rdzTuff is starting off with a positive reputation.
Quote:
My last tank gave me a combined mileage of 15.23 I got 457 miles out of the tank, and took on 30 gallons to refill it. Mostly city driving.
Old 04-10-2008, 11:48 AM
Golflug's Avatar
Golflug Golflug is offline
Golflug is starting off with a positive reputation.
When did champion come out with these plugs, when I did mine a few month ago they did not offer any plugs for the 5.4L. I used the autolight HT series. I see that the champion plugs are boasting a one piece design that will not break off in the engine, If thats the case, it may be the way to go
Old 04-10-2008, 01:49 PM
I Used Champion 7989 Plugs Pay $10 Ech. 1 Piece Plug And Seems O.k For Now.there Was No Way In Hell I Was Putting That Pos Motorcraft Design Back In.i Guess If They Change There Design They Might Admit To A Design Flaw And Be Somewhat Responsible For There Sorry A** Design.getting Sorry I Made The Switch To Ford Now.never Had So Many Problems !@29k
Old 04-11-2008, 11:02 PM
Sethw3's Avatar
Sethw3 Sethw3 is offline
Sethw3 is starting off with a positive reputation.
Thats a 20 dollar spark plug in Texas....????
Old 04-12-2008, 03:32 AM
ford-lover ford-lover is offline
ford-lover is starting off with a positive reputation.
Hi bigdokk9, did you changed the spark plugs when the engine was warm? or cold? 1st TSB recommended warm but 2nd TSB said cold. I am confused. Also, where did you buy the Champion 7989 for $10 a piece?
Thanks in advance for the info.
Old 04-13-2008, 12:31 PM
I pulled the plugs when eng was warm did one plug at a time as soon as the plugs started getting tight again I started truck for a couple of minutes and then moved on to the next one.DONT RUSH it they will definitley break.as for the price on the plug it was 9.?? each think they listed for 18-19 I pay wholesale im a tech at a shop if you know a tech ask him to get them.
spark plug success! gijim2k1 2004 - 2008 F150 0 04-26-2014 10:09 AM
Changing plugs and a little worried DonJuanDiego Modular V10 (6.8l) 3 03-23-2014 04:43 PM
Engine knock at idle. thuerka Modular V10 (6.8l) 3 11-27-2013 07:20 PM
Chasing my tail on misfire codes on 4.6 busflyer Modular V8 (4.6L, 5.4L) 6 11-19-2013 05:12 PM
Broken Plugs, Who Pays? Frd67cobra 2004 - 2008 F150 78 01-06-2008 05:57 PM
Tags
7989, champion, cost, dollar, edge, ford, number, plug, plugs, pluk, premium, price, problems, spark, twenty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
