302 EFI Roller Rockers / Valve Cover Clearance - Ford Truck Enthusiasts Forums
Old 05-28-2002, 12:02 AM
restorit's Avatar
restorit restorit is offline
restorit is starting off with a positive reputation.
Several questions regarding fitting roller rockers to a 302 EFI.... (1) Do all roller rockers require the use of taller valve covers (and, I'm assuming, a spacer to raise the upper intake manifold so it will clear)? Or, (2) Can you use the stock valve covers after removing some or all of the baffles? And, finally, I've been window shopping for valve covers (in case I'd need to change them) and have noticed that many that are listed for the 289-302-351W have a footnote that reads " * Not for EFI applications". Any idea what the difference would be? (assuming the stock EFI application used stamped steel rockers?) Thanks in advance!
Old 05-28-2002, 12:19 AM
lvstang lvstang is offline
lvstang is starting off with a positive reputation.
Removing the baffles allows you to run pedestal mount roller rockers. The FRPP valve cover will work with EFI but you have to add a 1" intake spacer, then you have to worry about hood clearance (on a Mustang)
Old 05-28-2002, 10:53 AM
cajunbronco cajunbronco is offline
cajunbronco is starting off with a positive reputation.
Some of the non EFI valve covers are designed to be used on non emissions vehicles that have breather vents on the valve covers and are not set up for a pcv valve.
BIlly
Old 05-28-2002, 06:12 PM
restorit's Avatar
Your replies are appreciated! lvstang..... so, if I understand this correctly, I should be able to run pedestal-mount type roller rockers under the stock valve covers if I remove or modify the baffles? I'm not terribly concerned with hood clearance, as the application is an '85 Bronco, so I'm guessing that my other option would be the FRPP covers and spacer.
Old 05-28-2002, 10:35 PM
14trax 14trax is offline
14trax is starting off with a positive reputation.
i just installed comp cam's roller tip magnium rockers in my 89 5.0. i used there stud kit. everything went togeather well using stock covers.
Old 05-28-2002, 11:10 PM
restorit's Avatar
That's great to know. Once again, the info is appreciated!
Old 05-29-2002, 01:40 AM
[updated:LAST EDITED ON 29-May-02 AT 02:42 AM (EST)]>Your replies are appreciated! lvstang..... so, if I
You're welcome.
14trax used the magnums which I believe have the stamped body with the roller tip. The Crane(Cobra) 1.7 rollers have the bigger aluminum body. I personally dig both the FRPP E-302 valve covers (too tall without the intake spacer) and the '83 finned "powered by Ford" covers which I had polished and cut out the baffles. I also sorta like the stepped aluminum cover that came on late '80's early 90's HO 5.0's. same baffles as the '83 covers.
You can drill any cover for PCV etc.
Old 05-29-2002, 10:22 PM
restorit's Avatar
Sounds good. Since I'm keeping the truck emissions legal (at least visually, and if I can build it right, the engine should pass the sniffer), I'd kind of like to keep the stock look. But, what the heck!? I'll probably never get a better excuse to put some sexier valve covers on it!
Old 05-29-2002, 11:32 PM
brett_d brett_d is offline
brett_d is starting off with a positive reputation.
High Efi valve covers 4x4man514 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 09-20-2015 10:57 PM
Roller lifters and rockers 85lebaront2 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 12 03-12-2014 05:51 PM
Roller rockers :) SuperDuty93 1973 - 1979 F-100 & Larger F-Series Trucks 42 10-23-2013 05:09 PM
valve covers dgriffinhere 1978 - 1996 Big Bronco 2 04-11-2013 12:40 PM
1.7 roller rockers deereford 1987 - 1996 F150 & Larger F-Series Trucks 27 01-14-2012 09:41 PM
Tags
302, 50, clear, clearancing, cobra, covers, efi, ford, rockers, roller, steel, stock, stud, valve, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
