Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Exhaust Systems
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Exhaust Systems
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-09-2008, 05:04 PM
djclass22 is starting off with a positive reputation.
Need Some Advice
Ok guys, bear with me on this one. I’m kinda old school. My first truck was a 1979 F150 4X4 with a 3” lift and 36.5” swampers. I ran headers with true duals consisting of twin Dynomax super turbo’s and straight 2.5” pipes. This was back in the early 90’s when emissions weren’t as strict and there wasn’t emissions testing in Rhode Island.
My next truck was a 1992 F350 extended cab dully. When I bought it (around 2004-2005ish) the first thing I wanted to do was a custom exhaust so I went out and purchased headers, high flo cats and another pair of super turbo’s. I had a custom exhaust shop do the work. By the time everything was done this guy hated me… It took him 3 days and a few knuckles just to get the headers in because this truck had a 460 in it and very little engine compartment room to work in. Well not only did the headers leak from day one, even after trying several different gaskets, but it threw the whole computer off. I ended up having to remove the headers and putting the original manifolds back on. That turned the check engine light off and it seemed to run good but the whole process was an expensive nightmare and a waste of a set of new headers.
I recently purchased a 1996 F250 4X4 with the 351 engine and just had a ton of work done including a new exhaust and manifolds. I really want a dual exhaust on this truck but am afraid to screw with it because of my last experience. Another concern is I live in Connecticut and there super strict with their emissions. I told the mechanic doing the work to make sure none of the emissions components were blocked off or removed.
What kind of exhaust setup can I install that wont screw up my emissions system. I’m just looking for a little sound and for the engine to breath better, no speed demon stuff.
Thanks!!
__________________
1996 F-250 4x4 "Ol' Red"
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-09-2008, 05:51 PM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
Your 351 would be difficult to dual out due to the way the sensors and converters are set up. The best route would be a dual outlet muffler.
Lets start with my recommendations on the headers.
JBA Smog legal headers are the way to go. You can get them so that they will bolt up to a the factory exhaust as well, though I'm sure you will be changing stuff out. They aren't the cheapest mufflers, but you can't go wrong with JBA.
If you want to stay with the stock cats, thats fine. You can get a little more performance with good high flow converters, but the factory system is ok too. the factory cat is not the best, the large size makes them quieter than most, and they can also slow down the exhaust more than a high flow cat will. What replacement you would need would depend upon what your current air tube setup is like.
This part would be fine if you do not have any air tubes, of if there is an O2 sensor in the rear of the converter
Item Details
For the dual tailpipes and a great sound, a good dual outlet muffler would be ideal.
Item Details
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
