torque specs/rod and main bearings - Ford Truck Enthusiasts Forums
Old 05-28-2002, 01:54 PM
gman7785 gman7785 is offline
gman7785 is starting off with a positive reputation.
does anyone have the torque specs for rod and main bearings on a stock,1995 5.0l(302) Ford truck?
Old 05-30-2002, 09:42 AM
cajunbronco cajunbronco is offline
cajunbronco is starting off with a positive reputation.
The conecting rod nuts are 40-45 Ft lbs.The main cap bolts are 95-105 Ft lbs.
Billy
Old 05-30-2002, 01:29 PM
stryder's Avatar
stryder stryder is offline
stryder has a good reputation on FTE.stryder has a good reputation on FTE.stryder has a good reputation on FTE.
Too tight to turn PapaBearYuma 1973 - 1979 F-100 & Larger F-Series Trucks 15 01-15-2017 08:20 PM
question about replacing main bearings PapaBearYuma 1973 - 1979 F-100 & Larger F-Series Trucks 16 11-12-2016 11:42 AM
Torque specs for tie rods hhcobra 1999 - 2003 7.3L Power Stroke Diesel 4 12-14-2015 01:14 PM
torque specs on main bearing caps when changing rear main seal engineguy33 1967 - 1972 F-100 & Larger F-Series Trucks 5 11-04-2005 06:50 AM
351 Windsor Main Bearing Torque Specification Wayne Harrell 1973 - 1979 F-100 & Larger F-Series Trucks 2 07-12-1999 12:17 PM
Tags
2003, 302, 35, 50, 50l, bearing, bearings, expedition, ford, main, rod, rods, spec, specs, torque, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
